Dodge Caravan 2005 Engine Codes P0404 AND P0522
I have dodge caravan 2005 has 130K + on it Please help me what is could be.Thanks.
I Check the oil and oil is ok.doesn't look low is there is any sensor that make the code P0522. and how to fix the EGR PLEASE help me with instructions.
I also had the P0404 code on my Caravan, I drove with it on for about two years. I have a code reader and would reset it once in a while to make sure that was all.
The EGR valve typically doesn't go bad if the vehicle is maintained and I didn't feel like dropping the 100 bucks for a new one. What normally happens when you get the P0404 is the electrical connection in the sensor gets corroded and the code is sent. If the Egr valve is bad you will also experience hesitation.
Pull the old one and see if the valve is moving freely, then it's most likely electrical.
On my van, 3.8 it's located on the left front of the engine compartment when you pop the hood. It's just bolts and an electrical connection. Here's what it looks like
http://www.autozone.com/autozone/par...uestid=1588554
Diagnose the P0522.
P0522 is the Diagnostic Trouble Code (DTC) for Oil Pressure Sensor Low and will appear if the oil pressure sensor voltage at the PCM drops .1 volts for 1/2 a second. You should also have a dash oil light for this, when it's occurring or when the computer "believes" it's occurring.
Step 1) Check oil. Are you low? Did you just do an oil change? Did you tighten the oil filter and the drain plug enough? Not the problem -Step 2.
Step 2) Inspect harness. It may be an Intermittent Code. A diagnostic trouble code that is not there every time the PCM checks the circuit is an intermittent DTC. Most intermittent DTC’s are caused by wiring or connector problems. Defects that come and go like this are the most difficult to diagnose; they must be looked for under specific conditions that cause them. The following checks may assist you in identifying a possible intermittent problem: Visually inspect related wire harness connectors. Look for broken, spread, bent, pushed out, or corroded terminals. Visually inspect the related harnesses. Look for chafed, pierced, or partially broken wire. If you have to start your car twice to get the oil light to turn off you might have an intermittent code.
Harness in good shape- Step 3.
Step 3) Replace the oil pressure sensor. Disconnect neg. terminal at battery. Still have an oil light? Have you pressure checked.
