axel ratios
Old 04-07-2009, 01:11 PM
kleezy's Avatar
kleezy
kleezy is offline
Default axel ratios
Hey! Would love as much input as possible. I've been told to avoid the 3.21 axel ratio. The ram I'm looking at right now has this ratio. I was wondering if anyone else has this and how they like it. Does it really make a big difference if I go with a different axel ratio. I'm just looking to cruise and not really do heavy towing or anything like that. THANKS AGAIN!
Old 04-07-2009, 02:04 PM
bigred3297's Avatar
bigred3297
bigred3297 is offline
not to be a jerk, but a good start would be to spell it axle and not axel...
other than that there are numerous threads on here about gearing, the search function can pull these up. This way we don't have a million threads about the same thing and can keep all the good info in one spot..
Old 04-07-2009, 05:53 PM
dodgewasp's Avatar
dodgewasp
dodgewasp is offline
I, like you, will not be pulling or hauling anything HEAVY. I have the 323 and I'm perfectly happy with it.
Dodgewasp
Old 04-07-2009, 06:17 PM
capsfloyd's Avatar
capsfloyd
capsfloyd is offline
I have the 3.21 gears and seems to be fine. I pull a 21' pontoon [ not heavy but catches a lot of wind]. I wanted the limted slip but could not get them unless you moved up to the 3.92? I drive about 3000-3500 a month and haul some material and ladders. I have the RAMBOX and really like working out of those boxes.
When I had my chevy 2006 ext. cab . it had the 5.3 v/8 and 3.30 gears , never had a problem.
Old 04-07-2009, 06:34 PM
chrisp929's Avatar
chrisp929
chrisp929 is offline
sir, please go test drive a TRX, all of those have 3.92 gears .. you will NEVER go back to 3.21's or what ever gears you have now ..
Old 04-07-2009, 07:27 PM
72combo's Avatar
72combo
72combo is offline
I had 3.92's in my 03 Durango, good out of the hole and could pull the hell out of trailers a few thousand pounds over its limit. oops don't tell.
Old 04-07-2009, 07:45 PM
kleezy's Avatar
kleezy
kleezy is offline
haha...ok...i'll go do some more research on the AXLE ratios....i appreciate the input guys! thanks...
Old 04-08-2009, 11:21 AM
70GS455's Avatar
70GS455
70GS455 is offline
I think it depends on the tire size. I have the 20" wheels (33" tall tires) and the 3.92 LSD. With that combo, the highway gearing was better (lower erpm) than my Dakota with 3.55 and smaller tires. Also don't forget that with the traction control, you will have electronic LSD via the brakes applied to a spinning wheel.
Quick Reply: axel ratios
