Removing interior door panel
Old 04-05-2009, 07:39 PM
madermu's Avatar
madermu
madermu is offline
Default Removing interior door panel
hey guys, i'm trying to remove the interior door panel to get to the speaker. I have the panel away from the door, but the handle is in the way.
anyone know the trick to get the panel over the handle?
thanks,
Old 04-05-2009, 07:46 PM
raminator08's Avatar
raminator08
raminator08 is offline
there should be a bolt behind the handle in the hole where the handle is. its hard to see but it pretty big once you find it. just unscrew it out and remove the handle
Old 04-05-2009, 07:48 PM
madermu's Avatar
madermu
madermu is offline
sweet, i'll give that a try......thanks!!
Old 04-05-2009, 07:52 PM
madermu's Avatar
madermu
madermu is offline
is it possible that there is 3 bolts?
thanks,
raminator08
no problem. let me know how it goes. i just replaced my door speakers and i have to say, it was one of the easiest mods i have done. the door panels came out in like 2 minutes and the speakers went it in like 5 min because they didnt exactly fit in. the speaker adapters made everything also much easier, no cutting wires
Old 04-05-2009, 07:53 PM
madermu's Avatar
madermu
madermu is offline
i have an '04 model, btw
Old 04-05-2009, 07:56 PM
raminator08
i dont think that should make much of a difference. just look for that bolt to remove the handle otherwise there is no way to remove the panel
Old 04-05-2009, 08:03 PM
irelandshemi's Avatar
irelandshemi
irelandshemi is offline
theres screws along the bottom as well and i think theres one up by where the mirror is
Old 04-05-2009, 08:07 PM
madermu's Avatar
madermu
madermu is offline
thanks guys.....i got the 3 screws at the bottom and the one at the top.....i think my handle has 3 bolts holding the door assembly.....
Old 04-05-2009, 08:09 PM
raminator08
well, you just need the remove the plastic handle. be careful not to remove the whole setup. maybe you should take a pic of it so we can get an idea
Quick Reply: Removing interior door panel
