4x4 conversion
Old 03-27-2009, 11:51 PM
dish_towel2000's Avatar
dish_towel2000
dish_towel2000 is offline
Default 4x4 conversion
has anyone done a 4x4 conversion with a d60 front end on a 2000 dodge 2500 diesel? if so what did you use for front suspension? coil or leaf? thanks
Old 03-28-2009, 12:30 AM
Alpheus's Avatar
Alpheus
Alpheus is offline
Its a piece of cake. If you can change your own wiper blades then you are ready for this conversion. All you need is a screw driver or a butter knife and a pair of pliers and you can have it done in your drive way in a weekend. I sell a conversion kit it costs around 10K all you have to do is use your screw driver to change the license plates.
Old 03-28-2009, 04:25 AM
dish_towel2000
haha sorry dude dont have 10k. just alittle info please i figure the simplest way would be to get a dodge 2500 front d60 axle sit it in place. weld up the control arms ( trailing arms) bolt the axle in place then slide the coils in. next drill holes for the steering box and connect the steering. last install a 4wd output shaft on the trans to hook up the transfer case then bolt in the driveshaft. or does it not work that way?
Old 03-28-2009, 07:10 AM
Alpheus's Avatar
Alpheus
Alpheus is offline
It does not work that way. The cheepest way Seriously would be to find a wrecked 4x4 and put your body onto it.
This here would be the cheapest way for you.
http://cgi.ebay.com/ebaymotors/Dodge...fCarsQ5fTrucks
Old 03-29-2009, 01:42 AM
dish_towel2000
im just going to start buying the parts and convert it just like i did to my 2wd ranger. wasn't hard just time consuming. thanks anyways.
Old 03-29-2009, 04:57 PM
Scott91370's Avatar
Scott91370
Scott91370 is offline
I would look at a junk yard for one that does not have front end damage. Buy the whole front clip- have them cut the fram right behind the control arms. This will give you everything you would need plus you could take all the measurements before you tear it apart. I would bet a few grand would be involved just because axles are not cheap.
Quick Reply: 4x4 conversion
