Ram 1500 solid axle conversion! HELP
Old 03-25-2009, 05:06 PM
revinthedodge16's Avatar
revinthedodge16
revinthedodge16 is offline
Default Ram 1500 solid axle conversion! HELP
I have 9" of lift on a 2002 Dodge Ram 1500 I would like to put a solid front axle in the front of it and get rid of all the IFS bull crap. What do I have to do in order to get this project done? Where can i get parts from? Like a refurbished axle or soemthing.
THANKS!!!
Old 03-25-2009, 05:35 PM
Seanutz's Avatar
Seanutz
Seanutz is offline
Id start at the junk yard. Pull a straight axle out of a 2500 and marry 'em up. Its just a simple matter of welding the appropriate brackets and getting it all together. the scrap yard is where you should start. New bushing and bearings and gaskets and what not would be a good idea too but you wont know what you need until you have the new (used) axle.
Old 03-25-2009, 06:41 PM
Alpheus's Avatar
Alpheus
Alpheus is offline
I wish it were that easy. I just went through all of this. I did allot of searching and researching and in the end I found the easiest way to do a solid axle swap.
Sell The 1500 And Buy a 2500!!!
I know that is not the answer you are looking for, but honestly that is the most cost effective way there is...
Old 03-25-2009, 06:58 PM
nim81's Avatar
nim81
nim81 is offline
+1! unless of course you have your own fabrication and machine shop.......
Old 03-25-2009, 08:18 PM
Rebeltilldeath3's Avatar
Rebeltilldeath3
Rebeltilldeath3 is offline
It's not hard at all, but if you don't know what you need, you probably can't handle it.
It would cost about $1k in parts.
Old 03-25-2009, 08:26 PM
whitealexander's Avatar
whitealexander
whitealexander is offline
yeah $1k is worth it.. since you will using it for a long time..
Old 03-25-2009, 08:34 PM
red06RAM's Avatar
red06RAM
red06RAM is offline
Check out this set up. https://dodgeforum.com/forum/members/6929-ce2flaco.html Click on "ram pics" in his sig. Also use the search fuction for more on solid axle swaps.
Old 03-25-2009, 09:29 PM
Alpheus's Avatar
Alpheus
Alpheus is offline
That swap above cost that guy well over 6K. You should do a bit more research in the cost of a SAS. If it only cost 1K I would have done it. Its a bit more complex than just a couple of welds and a couple of bolts. One of the hardest things to consider is how are you going to steer it? You cant use your rack and pinion steering on a solid axle. You gotta put a steering box in there somewhere. It costs more than 1K to do a SAS on an older Chevy and they make kits for that swap...
Old 03-25-2009, 10:07 PM
Rebeltilldeath3
It only costs $1k for a fabricator that knows what they're doing and doesn't think you need a "kit". Hell, almost everything you need can be easily found at a junkyard.
Just because one guy spent $6k, doesn't mean that's how much they cost. I could do one that cost $10k.
It doesn't matter what vehicle you have, a SAS will almost always require the same parts. The only thing that ever can get pricey is having a driveshaft made.
Now, if you have someone else do the work, it will get pricey because of all the hours. It's not hard, just a lot to do.
Old 03-25-2009, 10:21 PM
Alpheus's Avatar
Alpheus
Alpheus is offline
OK you do it then for under 1K. You cant do it!!! I have accsess to every piece of equipment that is needed for nothing? If it was so easy to do why hasnt the after market companies come up with a kit or a way to do it? Hell Dodge Ram is a heavy hitter in the world of 4X4 and this topic has been discussed on all the forums out there including this one the big name magazines and no one makes a kit. I can buy a SAS kit for Suzuki,Toyota,Chevy, and if you dont want to buy a kit you can at least find over 100 articles explaining a DIY SAS swap for one of those vehichles. But for some reason ( maybe you can come up with one) there is no DIY for a 3rd gen 1500. Maybe because it is cost ineffective. Meaning its cheaper to buy a 2500. The frames for a 1500 and a 2500 in the front are totally different and for his install He has torsion bars which makes it evn harder. The only way of doing for 1000 bucks is to cut the truck in half and have someone give him a 2500 that was totalled from being hit in the *** and cutting it in half and weld the two together. (MAYBE) I have talked to many people on this subject I even had the engineering dept. in my company throw all of this on there CAD system to come up with a way to do it cheap and easy with no results. These are 2 totally different trucks. (in the front)...
This has been discussed at length on this forum. Why dont you use that big brain of yours and use the SEARCH button and look for yourself!!!
Here Ill Help:
https://dodgeforum.com/forum/3rd-gen...axle-swap.html
https://dodgeforum.com/forum/3rd-gen...06-1500-a.html
This took me under a minute to find. You should try it too!!!
Quick Reply: Ram 1500 solid axle conversion! HELP
