2nd Gen Durango 2004 - 2009
airbag light comes on in dash panel!!!
Old 03-25-2009, 04:55 PM
The Punisher's Avatar
The Punisher
The Punisher is offline
Default airbag light comes on in dash panel!!!
my airbag light pops up and turns off once and awhile..sometimes when i take a hard turn or when i have my stereo system cranked up...my bass sometimes dims the lights and sometimes drop idle very low...what can it be?
Old 03-25-2009, 07:25 PM
1969CoronetR/T's Avatar
1969CoronetR/T
1969CoronetR/T is offline
vaffanculo
Maybe your choice of music?
FF
Old 03-26-2009, 12:25 AM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
Low voltage. Your charging system can't keep up. Probably tripping your sensor too as an aux sideaffect of low volts. My Subs can pull the alt down to 8 volts and that isn't good.
Time to get a 1Farad Cap installed pronto. It's cheaper than a new alternator.
IndyDurango
Old 03-29-2009, 09:19 AM
04Hermi's Avatar
04Hermi
04Hermi is offline
Originally Posted by The Punisher
my airbag light pops up and turns off once and awhile..sometimes when i take a hard turn...
Do you have a aftermarket sound system? If so you might want to see how it is grounded and verify you ain't shorting something out!
[quote=Maybe your choice of music?
FF [/quote]
Now that sh*t is funnie!
Old 03-30-2009, 05:37 PM
The Punisher
I am pulling alot of voltage....my grounds are good..I'm running 0 gauge wire...and i took all my engine grounds and did 0 gauge for them too.. but today i was not playing my music and my airbag light came on again...
Old 10-09-2009, 06:40 PM
jimmy stan's Avatar
jimmy stan
jimmy stan is offline
Default Durango air bag light
I have a 2001 Durango and the air bag light now comes on an off without any obvious reason either also. The dealer wants $110 just to pull the code. Does anyone have any ideas about why this happens?
Old 10-09-2009, 06:58 PM
1969CoronetR/T
vaffanculo
Autozone can pull codes for free or try the key in the ignition dance per Pyro's instructions. Post your codes once doen with the key dance:
https://dodgeforum.com/forum/3rd-gen...-for-this.html
FF
Old 11-10-2009, 09:24 PM
danab242's Avatar
danab242
danab242 is offline
Unhappy 2001 Durango air bag light off and on
I did what pyro said and the code i get is P done now what i tryed auto zone and they dont check here in california. I never will go to the dealer had bad experience with them if any one can help me
Old 11-11-2009, 12:33 AM
IndyDurango
P done means there is nothing in the system showing a problem. It is "Done"
IndyD
Old 11-11-2009, 07:45 AM
1969CoronetR/T
vaffanculo
Maybe a loose battery connection?
FF
Quick Reply: airbag light comes on in dash panel!!!
