Need a "wild vent" check valve Pic please!
Old 03-23-2009, 09:34 PM
mgj57's Avatar
mgj57
mgj57 is offline
Default Need a "wild vent" check valve Pic please!
My "wacky vent" problem is back again on my '96 1500 4x4. Last time it was the vacuum tube to the cruise mod under the battery tray. Replaced it, quick & easy fix. It's fine this time and research on the posts here seems to indicate that I might need to put the 4677204 check valve in. But, I can't figure out where it goes. I offered the guy at the parts desk a 12 pack and he told me I'd figure it out if you can believe it!
Anyone got a picture of where it goes on a '96? Or maybe I need to find a service guy who drinks beer!
Mark
Attached Thumbnails Need a "wild vent" check valve Pic please!-vacuum-007z.jpg
Old 03-23-2009, 09:45 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
these pics are from an 01, but it might help. the check valve in about the diameter of a quarter, maybe a little smaller, and about 1/4-3/8 thick. i think its at the beginning of your vacuum wad. its visible in my 3rd pic here, w/ the yellow stripe.
https://dodgeforum.com/forum/2nd-gen...cuum-leak.html
Old 03-23-2009, 09:53 PM
aim4squirrels's Avatar
aim4squirrels
aim4squirrels is offline
Look to the left of your PCV valve in your pic. The "T" in those vac lines ; the circular part in the
top branch is a check valve. The other one is just off the intake manifold. You have to pull the vac tubes apart to replace it.
Old 03-23-2009, 11:35 PM
J415's Avatar
J415
J415 is offline
Mark
I hope this helps. I think the guy at the parts deck didn't where it goes either. A lot of the time, from my experience, there all show and no go. There's a diagram that will show you what you need to know. A pictures worth a thousand words!!!
http://dodgeram.info/tsb/1996/24-01-96a.htm
There's gonna be a size differences going from one tube to the other. What I did, instead of buying reducers and other crap (I know I'm cheap), well let's say you have a 3/8's inch vacuum hose and you need to convert one side to fit a 1/2 fitting. Get a drill and a half inch drill bit and fit it over one side of the 3/8 inch hose, pinch it and power the drill on until you have your desired size. Worked great for me. It's a lot easier then it sounds...my vents are still "WILD" though.
Old 03-24-2009, 12:16 AM
mgj57's Avatar
mgj57
mgj57 is offline
great stuff guys... I'll give it a shot if I get off work early tomorrow. thanks!
Old 03-24-2009, 12:53 AM
Laramie1997's Avatar
Laramie1997
Laramie1997 is offline
look at the two links in my first post here: https://dodgeforum.com/forum/2nd-gen...ild-vents.html
Old 03-24-2009, 01:03 PM
J415's Avatar
J415
J415 is offline
Hey Laramie, I thought the TSB said not to block the air flow going to Reservoir because it will affect your cruise control. Did it work for you the way you did it?
Old 03-25-2009, 11:38 PM
mgj57's Avatar
mgj57
mgj57 is offline
Well guys, I haven’t been able to get to try any of your ideas on this after work this week since this wicked spring cold knocked me on my butt. I should be able to mess with it on Saturday. Cruise control is a problem too so I’m wondering if I’ve got a leak as well. I’ll let you know what I find.
Old 03-26-2009, 01:22 AM
Laramie1997
No it DID NOT affect the cruise control.... It worked for me, but only because I knew I didnt have a leak underneath the battery box, like most people have.
Old 03-27-2009, 10:43 PM
mgj57's Avatar
mgj57
mgj57 is offline
Red face
Well, it's fixed but it turns out it wasn't the check valve after all. My best advice? If you think you checked the vacuum line to the cruise mod under the battery tray - check again... AND, there is no substitute for a good old suck test!
It looked good... moved it all around with the tray cleaning acid off (should have been my first clue - but I had already replaced the darn thing once before) Failed the "suck" test - was rotten just inside the rubber boot where it connects to the cruise module. I just took an 1/8" drill bit to get the old piece out cut a clean end and shoved it back in. Good to go.
Of course now I feel like an idiot but someone will learn from my mistake. I hope!...
Thanks for the help and the pics!
Quick Reply: Need a "wild vent" check valve Pic please!
