2003 intrepid power steering problem
Old 03-21-2009, 08:29 PM
pontiac467's Avatar
pontiac467
pontiac467 is offline
Default 2003 intrepid power steering problem
when i replaced the 2.7 engine i figured i would change the alt and power steering pump while i was doing that. anyways the pump makes a wineing sound, i have tried bleeding the system by turning the wheel back and forth a million times and it does no good, it really sounds like crap and is kinda hard to steer like its low on fluid. i have replaced the pump with another new one and its doing the same thing.
What am i doing wrong?
Old 03-23-2009, 11:47 AM
harleyjames696's Avatar
harleyjames696
harleyjames696 is offline
check the lines and make sure the are not kinked or bent
Old 03-23-2009, 05:45 PM
pontiac467's Avatar
pontiac467
well i looked at the lines and they didnt look bent or anything, i also blew air through the line and it shot fluid out.
so i took it to the dealer today and its acting like its building air somewere because when you shut it off it forces fluid out the top and there is alot of bubbles in the fluid.
This is the 3rd pump i have bought , so they are going to take it off and look at it, but if it needs one im going to get a new factory pump instead of autozone crap i have been getting.
I really dont know what else it could be, the power steering worked just fine until i changed the pump, so you would think it would be the pump
Old 03-23-2009, 06:04 PM
harleyjames696
I WOULD HAVE FILLED THE PUMP AND THEN SPUN IT TO PRIME IT BY HAND FIRST. Let me know what they find out.
Old 03-24-2009, 04:36 PM
pontiac467's Avatar
pontiac467
well i got it fixed, the problem was a crappy o ring between the pump and resivor. It leaked a little bit and was causing air to build in the system.
thanks for the help
Quick Reply: 2003 intrepid power steering problem
