Timing chain cover coolant leak
  #21
Old 03-22-2009, 08:49 PM
TMS Bill's Avatar
TMS Bill
TMS Bill is offline
Rev it for a bit ... the bottom will get hot, too.
  #22
Old 03-23-2009, 12:07 AM
Dodge33's Avatar
Dodge33
Dodge33 is offline
I changed the oil, and drove to the store and back about 10 miles and got it on the freeway. No leaks, wierd noises, or engine lights and everything seems to be working. I guess I'm good to go. <knocks on wood>
Thanks to everyone that helped.
  #23
Old 03-23-2009, 12:39 AM
Rex-TheDOGG's Avatar
Rex-TheDOGG
Rex-TheDOGG is offline
Congratulations on a quality repair job!
  #24
Old 03-23-2009, 02:16 AM
Dodge33's Avatar
Dodge33
Dodge33 is offline
One last question... My oil pressure guage once warmed up sits just under 40 when idling and when driving under maintance throttle. However when accelerating, the oil pressure goes up above the 40 mark, and then drops back just under once I ease up off the throttle.
Is this normal or is the oil pressure supposed to stay level?
  #25
Old 03-23-2009, 07:31 AM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
normal.
congrats on the diy repair.
  #26
Old 04-04-2009, 09:32 PM
Dodge33's Avatar
Dodge33
Dodge33 is offline
During this repair the main thing that gave me trouble was removing the crankshaft bolt while keeping the engine from turning over. Thought I'd post a pic of the solution I used in case someone comes accross this in a search for the same issue.
Piece of flat steel bar, 24x3x1/8". Drilled three holes to match bolt pattern in harmonic balancer, and ground to fit around main bolt with a bench grinder. Hope it helps someone with the same problem.
Attached Thumbnails Timing chain cover coolant leak-crankshaft-tool.jpg   Timing chain cover coolant leak-crankshaft-bolt.jpg
  #27
Old 04-04-2009, 11:01 PM
TMS Bill's Avatar
TMS Bill
TMS Bill is offline
Sweet tool manufacture ... I'll keep that in mind.
  #28
Old 04-21-2009, 01:03 AM
olyelr's Avatar
olyelr
olyelr is offline
So, judging by this pic the pulley can be taken off before the bolt is removed? How, is it just pressed on there? I thought the bolt held the pully to the balancer.
  #29
Old 04-21-2009, 01:34 AM
WILLIAMJODI's Avatar
WILLIAMJODI
WILLIAMJODI is offline
6 bolts only hold pulley on
  #30
Old 04-21-2009, 07:27 AM
dhvaughan's Avatar
dhvaughan
the big bolt holds the balancer to the crankshaft.
its torqued real tight. 100+ pounds (135 maybe)
the 6 little bolts hold the belt pulley to the balancer.
he's using them, to hold the tool that stops the engine from turning - while he removes the big bolt. something like this is needed when using hand tools. not needed with air wrench.
Quick Reply: Timing chain cover coolant leak
