Check Gages light
Old 03-06-2009, 10:19 AM
Dodgey Dan's Avatar
Dodgey Dan
Dodgey Dan is offline
Default Check Gages light
Whenever i brake in neutral or downshift the check gauges light come on and dings for a few seconds, then goes away.Any ideas what this could be or how to fix it?..Thanks
Old 03-06-2009, 12:51 PM
rebel01m's Avatar
rebel01m
rebel01m is offline
did you check your oil latley or your collant
Old 03-06-2009, 01:56 PM
TMS Bill's Avatar
TMS Bill
TMS Bill is offline
Did you check your gauges ... what did you see? The light comes on when an indicator has traveled far enough out of the "normal" range.
Old 03-06-2009, 07:29 PM
Dodgey Dan's Avatar
Dodgey Dan
Yeah all new gaskets (needed head gasket), flushed coolant, and oil replaced, tuned..gauges seem fine?...
Old 03-06-2009, 07:40 PM
TMS Bill's Avatar
TMS Bill
TMS Bill is offline
You'll only see the "Check Gauges" light when there is a gauge indicating a bad condition. It's a Master Caution light. There is nothing wrong with the gauges ... they're trying to tell you that there's something wrong with the truck. Asking why you're getting a "Check Gauges" light is like saying, "I have a 'Check Engine Light' ... what's causing it"? We need more information.
Old 03-20-2009, 10:30 AM
Dodgey Dan's Avatar
Dodgey Dan
Ok i checked everything over, i noticed when the light comes on the oil pressure drops to 0, then it will go back up to normal..again only when stoping in neutral or down shifting. The oil pump seems fine, everything works great except for then. Any ideas??
Old 03-20-2009, 11:44 AM
TMS Bill's Avatar
TMS Bill
TMS Bill is offline
First, run a cluster check. Key off, press and hold the trip reset button, key on, hold button until the odometer says "CHEC" (5 or so seconds) ... release button and watch the cluster run through it's self test. Pay close attention to the third section where the gauges run through a sweep test. Watch the oil gauge. Do it a number of times. If that looks good, either change out the sensor or ring the wire while moving it around really good to see if you get an open. The oil pressure tap is at the back of the engine, beside the distributor.
Old 03-20-2009, 12:26 PM
Kindschi's Avatar
Kindschi
Kindschi is offline
Could be a bad oil sending unit, Happened to my roomates truck, whenever he was stopped at a red light or coming down in gears it would come on and pressure read 0 when in fact it was fine. I have seen several Chrysler's come in with this, mainly Rams and Caravans.
Old 03-20-2009, 05:02 PM
dblj16380's Avatar
dblj16380
dblj16380 is offline
I'm not trying to make you sound bad or anything, but have you checked your oil level? My truck burns a little oil and one day it did exactly what you are describing and I checked my oil and sure enough, I was low. I filled it back up and the problem went away.
Old 05-02-2014, 10:01 AM
jeskah.m's Avatar
jeskah.m
jeskah.m is offline
Default Different Outcomes
For the people saying have you checked your oil lately....
My father has his truck, a 2001 Dodge Ram, serviced regularly and has a receipt for ever three months or every three thousand miles, whichever comes first in his truck, which I very clearly had to dig through to find the truck manual; However, I was driving it and all of a sudden, fuel gauge and oil pressure gauge dropped and the truck stopped running. Had to pull off on the side of the highway in BFE WYOMING and wait hours for someone to come and assist us in getting the thing running again. It just was serviced like...last week when my dad replaced the brakes and there is nothing wrong with the oil level. Trying the trick above, will let everyone know how it turns out.
Last edited by jeskah.m; 05-02-2014 at 10:02 AM. Reason: left out make/model of truck
Quick Reply: Check Gages light
