window off track?
Old 02-25-2009, 10:55 AM
natenwman's Avatar
natenwman
natenwman is offline
Default window off track?
my window is not workin at all. the window falls down and ive had to prop it up with tape and cardboard. I can hear the motor running when i try to work it and when i took the door panel off the cables are fine (no snaps or frays) but i couldnt really see much else. so i got a couple of questions
1. is the window just off track? if so can i fix this easily myself?
2. Or is it the window regulator? I had one go out on another door and got charged 350 for the fix. is there any place i can get a cheaper part and would yall recommended fixing this myself?
Old 02-25-2009, 11:41 AM
Mean Green's Avatar
Mean Green
Mean Green is offline
Fix it yourself for sure it isn't a tough problem. Normally it is the cable that snaps but I guess we've been through that already. Pull the panel off and just start digging around you are bound to find the problem. It is likely you will have to buy a whole new assembly though.
Old 02-28-2009, 01:30 PM
natenwman's Avatar
natenwman
ive looked around for the parts and they all seem to be kind of expensive when new.would you recommend buying a used part from a junk yard or pull a part or am i lookin for trouble in the future?
Quick Reply: window off track?
