Camshaft Position Sensor and Cruise Control
Old 02-16-2009, 09:04 AM
whoami5423's Avatar
whoami5423
whoami5423 is offline
Default Camshaft Position Sensor and Cruise Control
I was wondering if I could have some more experience opinions on a problem that recently came up on my 2003 Neon SXT. About 2 weeks ago the check engine light came on in my car. I did a manual test (turn the car on and off 3 sec so that the OBDII Codes are shown) and found that I had a P16 code and P344 code. This engine light turned off about 2 days later then came on and off again last week and now just came back on yesterday (with the addition of a P340 code)!
I'm thinking I need to replace the Camshaft Position Sensor but I was wondering if anyone else had any other ideas of what else I should get checked. The reason being is that I don't know what a P16 code is and apparently, according to my wife, the cruise control isn't working now! Could it be a bad computer? Is the cruise control anyway related to the Camshaft issue? Anything I should get checked? (any specific fuses, relays, wiring?)
Thanks for your help!
P0344
Camshaft Position Sensor Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
Old 02-16-2009, 01:42 PM
uh-man-burger's Avatar
uh-man-burger
uh-man-burger is offline
I had the camshaft position sensor problem with my 04 2 summers ago. I don't remember if it was messing with my cruise control though. I bought the sensor and my dad changed it for me, and my car ran much better. If you are changing it yourself, maybe just change it and see if it makes the cruise work again.
Edit: most auto supply stores with the code computers have a book of codes to tell you what's wrong with the car.
Old 02-24-2009, 02:26 PM
whoami5423's Avatar
whoami5423
Thanks for the response. The Check-engine light went on and off a few times since my last post and definitely correlated with the cruise control. As of Sunday, I have replaced the sensor and everything has been running great.
Thanks uh-man-burger for actually taking the time to respond!
Old 02-27-2009, 12:51 PM
darthroush's Avatar
darthroush
darthroush is offline
Section Moderator
I missed this one, but I would have suggested changing the sensor as well. Glad to hear all is well again!
Old 03-04-2009, 03:03 AM
neonftw87's Avatar
neonftw87
neonftw87 is offline
i would also keep a check on your clockspring, it controls your horn, airbag, and cruise control, its located in your steering column, just under your steering wheel
Old 03-29-2009, 06:07 PM
ottoretto's Avatar
ottoretto
ottoretto is offline
Default camshaft sensor
Hello fellows, iunno how the camshaft sensor works 1g neon!, i want to know that... and the function of each cable... thanks! 1g neon!
Old 03-31-2009, 03:20 AM
darthroush's Avatar
darthroush
Section Moderator
Um, well. I can't understand that (no offense), but either way, you may have better luck in the 1st gen Neon section instead of the 2nd.
Old 04-04-2009, 03:21 PM
rvrfsh's Avatar
rvrfsh
rvrfsh is offline
Question cam sensor keeps going out
I have changed my cam sensor a couple of times now and it still keeps going out. It does good for awhile after putting a new sensor in but eventually comes back to same problem. Any ideas are greatly appreciated. PLZ HELP!!!!!!
Old 04-05-2009, 12:06 AM
ewetho's Avatar
ewetho
ewetho is offline
Newer cars have computer controlled Cruise Control. The computer can't control the engine properly it will not control the Cruise. Safety issue. Older more mechanically based ones were unaffected.
Old 04-05-2009, 02:05 AM
darthroush's Avatar
darthroush
Section Moderator
Are you using aftermarket ones? Perhaps try a factory one?
Quick Reply: Camshaft Position Sensor and Cruise Control
