04 Stratus P0303 Cylinder 3 Misfire Detected
Old 02-10-2009, 11:40 AM
skibumsoccerbum's Avatar
skibumsoccerbum
skibumsoccerbum is offline
Default 04 Stratus P0303 Cylinder 3 Misfire Detected
Hello all. I started up my stratus yesterday morning and it was idiling really rough and the check engine light came on. I took it to autozone and got the code read out of P0303. I replaced the spark plugs last night, and started the car back up, the check engine light still came on. Before I get drastic and take it to a dealership, is there anything else that I could do to fix this issue. Any info would be a great help.
Thanks
Old 02-10-2009, 03:13 PM
ratsttam's Avatar
ratsttam
ratsttam is offline
There is a couple other things to check.
I would start with the plug wires, and work back to the distributer (or coils, whatever you have).
Old 02-10-2009, 06:04 PM
tomthedog's Avatar
tomthedog
tomthedog is offline
did you have the code cleared? if not it, may take a bit to self clear. just a thought.
Old 02-10-2009, 07:17 PM
pearl01stratcpe's Avatar
pearl01stratcpe
pearl01stratcpe is offline
coupe or sedan?
Old 02-11-2009, 03:27 PM
skibumsoccerbum
Thank you for your suggestions. I ended up trying the key trick with turning it on off, on off, on off. It popped up the code P303, but than when I went to start the car the check engine light did not come back on after that, and I have driven it a couple of times and still no sign of it coming back on. I hoping that it was just the spark plugs, they did look pretty ugly after I replaced them. Hoping that it isn't a sign of bigger problems to come in the future.
Old 04-06-2009, 10:31 PM
junkdls's Avatar
junkdls
junkdls is offline
Hey. My daughter's '04 Stratus with about 98K miles popped this code this afternoon. I just replaced the plugs about two weeks ago, and it has been running fine.
It has a coil on top of each plug. This is the first vehicle that I have changed the plugs on that has a coil on each plug. Is there anything special I should have done? The "wires" below each coil just seemed to rest on each plug. The didn't have the typical loop that had a positive snap onto the plug, so I was never really sure if each was properly seated.
Any ideas on what I should check? I'll clear the code when I get ahold of a friend's reader to see if it was a fluke or comes back, but am wondering if I missed something?
Thanks!
Old 04-07-2009, 06:34 AM
pearl01stratcpe
Mine did this, and over time, it ran like total crap. I ended up having to replace both coil packs at $100 a piece. I have also read that on this particular car, (The 2.4 SOHC mitsubishi motor) that the coil packs 'fight' platinum plugs. I have been using the cheapest plugs I could find for 2 years now and havent had issues.
Old 04-07-2009, 02:36 PM
junkdls's Avatar
junkdls
junkdls is offline
Uh oh. I try to buy copper plugs, but Wally World only had platinum plugs when I replaced them. If it persists, it looks like I'll be replacing them again.
Thanks for the info.
Quick Reply: 04 Stratus P0303 Cylinder 3 Misfire Detected
