2000 Dakota power steering pump replacement--what do I need?
Old 02-04-2009, 02:19 AM
fastfeat's Avatar
fastfeat
fastfeat is offline
Default 2000 Dakota power steering pump replacement--what do I need?
I've got a 2000 Dakota thrasher with about 150K. Power steering pump pukes out a pint of fluid every few days, so I'm figuring the pump needs to be replacement. What tools, how much time am I looking at for R and R.
Old 02-04-2009, 02:25 AM
f0x672's Avatar
f0x672
f0x672 is offline
check to make sure your lines arent garbage let alone the rack isnt bad either
Old 02-12-2009, 01:19 AM
huseman808's Avatar
huseman808
huseman808 is offline
if i remember right, from when i replaced mine... You just need a pump. 1st or 2nd Gen Dakota will work. maybe grab a can of stop leak for power steering if you have any minor leaks when your done. should be fairly simple though. You will have to remove the inner fender well to get at the lines i believe. The total job took me about an hour.
Quick Reply: 2000 Dakota power steering pump replacement--what do I need?
