5.7 Hemi spark plug change
Old 01-26-2009, 09:29 PM
classicmoparnut's Avatar
classicmoparnut
classicmoparnut is offline
Default 5.7 Hemi spark plug change
Have a 2006 dodge charger daytona with 30000miles.
Manual says change plugs at 30000 Just wondered how much trouble to change as the dealer wants a bunch and I have worked on older cars all my life.
Old 01-26-2009, 10:36 PM
MangoInTX's Avatar
MangoInTX
MangoInTX is offline
Charger Moderator
It take a little while but their not bad to get at, I do mine in about an hour taking my time.
Stock plugs are Champion RE14MCC4 Copper Plus Plugs. Rockauto has the best price that I found.
Take the wires off the coil packs via quick disconnects. You'll need a 10mm socket/wrench to take off the coil packs (two per pack). Once loose just pull up on the coil packs to remove them. This gives you access to the plugs, 2 per cylinder (16 total).
gap .045 torque 13 ft lb (use antiseize on the new plug threads)
Old 01-27-2009, 06:34 AM
MangoInTX's Avatar
MangoInTX
Charger Moderator
I forgot to welcome to the forum classicmoparnut... Welcome! GoManGo rocks!
Old 01-27-2009, 01:27 PM
classicmoparnut
thanks for the information
thanks for the information sure will help
Old 09-20-2010, 08:18 PM
hpowell9742's Avatar
hpowell9742
hpowell9742 is offline
How difficult is it to put the coil packs back on!?
Old 07-02-2012, 06:48 PM
wgl0@comcast.net's Avatar
wgl0@comcast.net
wgl0@comcast.net is offline
Default Bill
Is there a shop manual page showing the coil packs and wires that can be sent?
Old 07-02-2012, 09:52 PM
Paisanyc's Avatar
Paisanyc
Paisanyc is offline
I just changed 16 plugs on my 05 durango...@85k
Pretty sure they were still the originals.
Old 05-06-2013, 07:34 PM
kennyt's Avatar
kennyt
kennyt is offline
Just changed my plugs in my 04 Durango, still original, 199,920 miles on them, still running good. Now thats some miles.
Quick Reply: 5.7 Hemi spark plug change
