Valve adjustment?
Old 01-20-2009, 08:05 PM
dieselpotato's Avatar
dieselpotato
dieselpotato is offline
Default Valve adjustment?
I have an 04 Ram 24valve... how often do we need to get a valve adjustment?
Old 01-20-2009, 08:39 PM
Coal Train's Avatar
Coal Train
Coal Train is offline
It's not "scheduled" until 100K.
Valve adjustment is fairly simple.
A 1/2" breaker bar and 15mm socket to turn the engine over to TDC twice
A 9/16" box / open end wrench to loosen / tighten the jam nut
And, I believe, a 4.5mm or 5 mm allen wrench to adjust the lash.
.008, .010, .012, .020, .025, .028 feeler gauges.
.010 on the intake, .025 on the exhaust ( I usually do mine at .020 to get rid of a little valve train noise).
Old 01-22-2009, 03:59 PM
Jesse James's Avatar
Jesse James
Jesse James is offline
Default check this out,
I found this on another forum, I had the same ?,
http://www.dieselbombers.com/5-9-lit...tment-diy.html
Quick Reply: Valve adjustment?
