Catalist 420 code?
Old 01-15-2009, 12:20 AM
caggi's Avatar
caggi
caggi is offline
Question Catalist 420 code?
"MIL" (ck eng) light is on for a PO420 DTC? Do I need a new cat? I would appriciate anybody who could help. thanks
Old 01-15-2009, 08:20 AM
aim4squirrels's Avatar
aim4squirrels
aim4squirrels is offline
P0420 is catalytic converter efficiency below minimum specs.
Probably time for a new cat, but have you changed anything else? it could also be a dirty O2 sensor. you can clean them with electric parts cleaner. you can also use carb/choke cleaner if you're careful
Old 01-15-2009, 05:35 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
You could also fill in the specs about your truck when you register! And it's probably time for a new lower intake gasket.
Old 01-15-2009, 06:02 PM
xskylinedx's Avatar
xskylinedx
xskylinedx is offline
Just remember if you do in fact need a new cat check out summitracing. I picked up a
hi flow stainless steel magnaflow cat for under $100.
Old 01-15-2009, 06:49 PM
94Beater's Avatar
94Beater
94Beater is offline
Wink
420 Hmmmmmmmmmm ?? - Not enought THC in your system
Old 01-16-2009, 05:35 PM
caggi's Avatar
caggi
caggi is offline
Default thanks for the replies
I'll try cleaning the sensor, how do I know if it's the sensor or the cat? Or the intake gasket? I haven't done anything yet, just some banging on the muffler and it's loose inside. The cat might be too haven't hammered on that yet.
(I try to get more THC in, maybe I'll forget about that durned light! )
Quick Reply: Catalist 420 code?
