humming noise from front end
Old 01-03-2009, 03:39 PM
lowone01's Avatar
lowone01
lowone01 is offline
Default humming noise from front end
I am getting a humming noise on the front driver side of my 2002 neon it sounds like i have a set of mudd tires on any ideas.
Old 01-03-2009, 05:27 PM
mcfisher1980's Avatar
mcfisher1980
mcfisher1980 is offline
suspension maybe. when was the last time you checked the air pressure in the tires
Old 01-03-2009, 09:31 PM
darthroush's Avatar
darthroush
darthroush is offline
Section Moderator
More info will help. When did it start, when does it do it, how long has it been making the noise, etc...
Old 01-04-2009, 04:11 AM
04neonrtguy's Avatar
04neonrtguy
04neonrtguy is offline
Definetely sounds like a tire pressure issue to me. Sometimes i hear people that sound like they have a flat tire (almost the same humming sound as a mud tire would make), when they are really driving with one tire somewhere between 1/2 and 3/4 recommended tire pressure.
Old 01-04-2009, 09:57 AM
smallblockfreak's Avatar
smallblockfreak
smallblockfreak is offline
Your wheel bearing is going. It will make the car sound like it has mudders on it. Take for another drive and start turning the wheel one way then the other way and it should get louder one way than the other.
Old 01-28-2009, 05:26 AM
neonftw87's Avatar
neonftw87
neonftw87 is offline
yes, smallblockfreak makes a good point, could most definantly be the wheel bearings, another way that may help diagnose if its this is when you hit a small bump or anything like that if you can hear like a small clanging noise... id check the wheel pressure first to make sure its correct, i keep mine about 32lbs, then if they are good, i would go ahead and pull the tire off and check everything else...
also, if it pulls to the right... could mean your right caliper could be sticking which could make a small roaring noise... but if its not pulling to one side or the other, i wouldnt worry about the braking system
Quick Reply: humming noise from front end
