Old 08-14-2015, 06:37 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
Installing shocks????????
Old 01-01-2009, 08:02 PM
hemidel's Avatar
hemidel
hemidel is offline
Default Installing shocks????????
I have a 2004 Dodge Ram 1500 Quadcab 4x4 and was wondering how hard it is to replace those shocks. I've called around here and there, and it will cost anywhere from $65-$118 shop labor to install bilsteins all around. My truck just rolled over 90,000 miles, so I want to do some preventive maintance and replace the shocks. Should I try to attempt this myself? Any input would be helpful......
Old 01-01-2009, 08:52 PM
nim81's Avatar
nim81
nim81 is offline
shouldnt be too hard. shock replacement is usually pretty straight foward, all you should need tool wise is a socket set and some wrenches. very simple if you are mechanicaly inclined. might wanna hit the bolts with some pb blaster before you start just to make sure they break loose in case they are siezed up.
Old 01-01-2009, 08:53 PM
CreativeOffroad's Avatar
CreativeOffroad
CreativeOffroad is offline
It's probably do-able yourself, but I would have it done professionally just because that's a pretty important part to not have installed and working properly. Just my 2 cents.
Old 01-01-2009, 09:10 PM
nim81's Avatar
nim81
nim81 is offline
there really isnt anything you can mess up unless you dont tighten the bolts down. shouldnt take more than 30min at most for all 4 shocks.
Old 01-01-2009, 09:42 PM
CreativeOffroad
Yea it didn't take them much more than 30min when they installed mine, it also cost relatively nothing (it pays to know the guys who work on your truck) so I guess I'm a little biased.
Old 01-01-2009, 09:59 PM
hemidel's Avatar
hemidel
hemidel is offline
What did you have installed on yours CreativeOffroad?
Old 01-01-2009, 10:03 PM
ramhunter9's Avatar
ramhunter9
ramhunter9 is offline
if this shop labor includes the shock thats a heck of a deal if not +1 to all the above its pretty easy.
Old 01-01-2009, 10:08 PM
hemidel's Avatar
hemidel
hemidel is offline
No, that shop labor just includes installation. Im thinking about getting the shocks from offroadwarehouse.com @ $279 for all four...
Old 01-01-2009, 10:12 PM
ramhunter9's Avatar
ramhunter9
then you would be better doing it yourself and spending the money you had for install on a CAI another easy install
Old 01-02-2009, 12:58 AM
OlDirtyJohn's Avatar
OlDirtyJohn
OlDirtyJohn is offline
just did bilsteins on all 4 corners couple weekends ago on my truck. dont pay someone to do it. its too easy to do on your own. i did all 4 shocks by myself in 45 min to an hour. and that includes having a couple too many beers in the process. all you need is a crescent wrench, basic socket set, and an extension.
on another note... the Bilsteins are AWESOME! night and day difference compared to the stock shocks. really smoothed out the ride on my 2500.
Quick Reply: Installing shocks????????
