Transmission identification
Old 12-24-2008, 07:28 PM
trent921's Avatar
trent921
trent921 is offline
Default Transmission identification
Can someone break down this transmission id from my 94 Ram,1500, 2 wheel drive?
PK52118324 1945 1140
I know from reading past posts that it says the build date, and a serial number. Does this number tell me exactly what tranny I have. By reading the posts I probably have a 46RH, but I want to be sure. Does the PK5211 refer to the 46RH?
Any help would be appreciated.
Old 12-24-2008, 07:49 PM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Dodge only used two different automatic transmissions for 1994-2001 model years of 1500s and the Dakotas. The 42RH (1994-1995)/42RE(1996+) for V6 applications, the 46RH/46RE for V8 applications.
Old 10-15-2011, 03:24 PM
tomdel45's Avatar
tomdel45
tomdel45 is offline
how do i tell which transmission i have on my 1997 dodge ram 4x4 pick up the vin is telling me ASP. the tag on it shows
52118 156 119463 2 A4 B3
Old 10-15-2011, 03:31 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
You have a 46RE, simple as that. Also referred to as a 518 at times. But they are not all the same.
Old 10-15-2011, 04:10 PM
gdstock's Avatar
gdstock
gdstock is offline
Somewhere in the FAQ/DIY section I believe there is a thread that tells how you can obtain a build sheet on your truck. It will tell you which options and what equipment came on the truck. Handy to have around. They respond very quicly in an e-mail. Jeep will not send it if you are not the registered owner, citing security issues, but Dodge does not get that p*****.
I guess national security may be at risk if I knew what equipment came on my brother in law's jeep............
Old 10-15-2011, 05:05 PM
zman17's Avatar
zman17
zman17 is offline
Here is the link to get a build sheet. But it does not change the fact that he has a 46RE tranny. http://www.dodge.com/wccsapp/univers...ull&category=U
Old 10-15-2011, 06:14 PM
gdstock's Avatar
gdstock
gdstock is offline
This is true, but it may help him with other items such as rear end and other things he will surely need to know about in the future.
Old 11-10-2011, 03:21 PM
vicsponjr's Avatar
vicsponjr
vicsponjr is offline
Can you look at the transmission and tell them apart, or do you need the build sheet?
I have a 99 1500, 4wd
Old 11-10-2011, 03:22 PM
What size engine?
Old 11-10-2011, 03:25 PM
zman17's Avatar
zman17
zman17 is offline
46re....
Quick Reply: Transmission identification
