Clearing 2002 Ram 1500 pcm
Old 12-22-2008, 10:49 PM
nh5's Avatar
nh5
nh5 is offline
Default Clearing 2002 Ram 1500 pcm
can someone give me the procedure for resetting the pcm on my 02 5.9L. Is it different from the newer rams?
Old 12-22-2008, 11:09 PM
SmokeySportRam's Avatar
SmokeySportRam
SmokeySportRam is offline
resetting what? You can unlook the battery for a half hour, that will clear everything
Old 12-23-2008, 11:10 AM
OldMoparMan's Avatar
OldMoparMan
OldMoparMan is offline
Pull fuse #19 under hood in the black, "L" shaped fuse block with the screw on the top.
Sit in truck, close door and put seatbelt on.
Turn key to "ON" position, but do not start.
With key on, you'll hear 2 chimes.
After that, turn truck off, replace fuse #19.
You're good to go...................
Quick Reply: Clearing 2002 Ram 1500 pcm
