Old 08-05-2015, 09:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Guides
Print Wikipost
Throttle Body Cleaning (with pics)
Old 12-22-2008, 06:08 PM
fox_racer627's Avatar
fox_racer627
fox_racer627 is offline
Default Throttle Body Cleaning (with pics)
I got really bored today and decided to clean my throttle body. It looked dirty when I looked through the butterfly valve and I was right. there was carbon and varnish all over the inside of the throttle body and the intake (which i cleaned what i could reach aswell). How did it get so dirty? I expected a little but there was alot of varnish and carbon on there. The truck only has a little over 50,000 miles on it and I've taken excellent care of it. This was my first time cleaning the throttle body and will definitley not be my last.
Heres some before and after shots (crap quality iphone pics and I dont know how to resize):
Before:
After:
Old 12-22-2008, 06:11 PM
Jimmeh's Avatar
Jimmeh
Jimmeh is offline
Looks WAY better.
Which reminds me that I need to do the same.
Old 12-22-2008, 06:22 PM
JoeHemi's Avatar
JoeHemi
JoeHemi is offline
Looks good, what did you use to clean it with? Also, about how long did it take from taking the TB off, cleaning it, and reinstalling it?
Old 12-22-2008, 06:31 PM
fox_racer627
It was VERY easy to do. I have a CAI so I didnt have to take the hemi hat off.
I just loosened the clamp from the CAI to the throttle body and then unlugged the IAT sensor. I then used an 8mm socket wrench to take loose the four bolts holding the throttle body on and unhooked the sensor on the top, disconnecting it from the intake. It only took me about 7 minutes to get the throttle body off. i then used a wire brush to clean the heavy carbon off and carb cleaner on an old tshirt to get the varnish off. I got the tight spaces with carb cleaner on a Q-tip. WHATEVER YOU DO DO NOT SPRAY CARB CLEANER INTO OR USE COMPRESSED AIR ON THE THROTTLE BODY. The eleectronics are not sealed and are easily damaged. installation was the reverse of the removal. Just torque the bolts to 105 in. lbs or 8.75 ft. lbs.
Old 12-22-2008, 06:34 PM
fox_racer627
Oh yeah, total time was about 35 minutes. 15 for removal/installation, and 20 for cleaning (plus about 15 if you clean the intake).
Old 12-22-2008, 06:50 PM
JoeHemi's Avatar
JoeHemi
JoeHemi is offline
Good info, I may do this next weekend. I'm sure it's filthy and I also need to replace my EGR. Thanks for your input
Old 12-22-2008, 06:57 PM
fox_racer627
No problem. Let me know if you have any more questions.
Old 12-22-2008, 08:48 PM
fgee's Avatar
fgee
fgee is offline
fyi.... our tb's have a special coating on them you just removed it using carb cleaner I do not recommend using any solvents on the tb use a clean rag and wipe it clean
V_Scapes's Avatar
V_Scapes
V_Scapes is offline
thanks for the post, i might try and do this this week when i put my intake in, as well as a oil change.
Old 12-22-2008, 09:20 PM
fox_racer627
What is the coating made of? And what does it do? I wouldnt think it would make much of a difference....
Quick Reply: Throttle Body Cleaning (with pics)
