tools needed for rear brake job?????
Old 12-16-2008, 06:04 PM
jp196400's Avatar
jp196400
jp196400 is offline
Default tools needed for rear brake job?????
hey guys just need to know if any special tools are needed to do a rear brake job on an 04 ram??
thanks
Old 12-16-2008, 07:21 PM
Stunnerguy's Avatar
Stunnerguy
Stunnerguy is offline
When I did my pads and rotors I needed a c-clamp to push the pistons in, other than that it's just basic tools.
Old 12-16-2008, 07:31 PM
SmokeySportRam's Avatar
SmokeySportRam
SmokeySportRam is offline
a 10 mm socket (im 99% sure) a screwdiver or small prybar, and a C-clamp.
thats it
Old 12-16-2008, 07:38 PM
sos's Avatar
sos
sos is offline
Do you have drum or disc brakes in the rear? If you have drum brakes, get a small drum brake tool kit available at the auto parts stores. They are usually pretty cheap and will help getting all those springs in place.
Old 12-16-2008, 08:10 PM
manogmin's Avatar
manogmin
manogmin is offline
you should need a 1/2 socket for the caliper bolts, and i think 13/16 for the caliper bracket bolts, and a c-clamp and something to lay across the pistons in the caliper to re-compress them. thats it. and a 7/8 socket for the lug nuts.
Old 12-16-2008, 09:57 PM
jp196400's Avatar
jp196400
jp196400 is offline
ok so the rotors just com off when the wheel comes off??
also the piston in the calipers can just be pushed in?? it doesnt need to be turned in??
Old 12-16-2008, 10:20 PM
casper3380's Avatar
casper3380
casper3380 is offline
you will need a few sockets, metric most likely(havent done brakes on mine). I would recommend a drain plug wrench so as too release pressure when pushing the piston back. If you do i would recommend priming the line, otherwise(when you have the caliper off) put one of the old brake pads on the piston. then apply the c clamp to the old pad and the other side of the caliper, and tighten. They are zero clearance and will adjust the first time you apply brake pressure. If you do prime the brakes, remember to not get any brake fluid on the body of the truck, it will destroy your paint. Also for bout the first 500 miles try not to slam on the brakes(ok if you have ceramic pads), it could cause the rotor to heat up before the pads seat, causing hard spots and damaging the pads. Also, are you either putting on new rotors or having them refinished? Dont put new pads on old rotors. hope that helps.
Old 12-17-2008, 12:01 AM
jp196400's Avatar
jp196400
jp196400 is offline
thanks for all the help guys I am going to put on new pads and rotors I just want to make sure I have all the tools before I start otherwise I have no way of getting to the parts place lol
Old 12-17-2008, 03:32 AM
abarmby's Avatar
abarmby
abarmby is offline
If your e-brake has the shoes internally fitted into the rear rotor, you will need a BIG HAMMER to bray off the rotor.
Al.
Old 12-17-2008, 09:28 PM
manogmin's Avatar
manogmin
manogmin is offline
the e-brake shoes are located on the inside of the rotor but i have never had a problem getting the rotor off due to the shoes, but there is usually a push on nut on one of the studs, you will have to get that off before the rotor.
Quick Reply: tools needed for rear brake job?????
