Transmission PO734,PO700
Old 12-13-2008, 02:51 PM
robolama5's Avatar
robolama5
robolama5 is offline
Default Transmission PO734,PO700
1999 Dodge G Caravan. I am In Limp Mode with codes PO734,PO700.So I went to change the Output Speed Sensor and I found a lot of metal flakes stuck to the end of it but I don't have any flakes on the transmission dip stick. What now? Is there any thing I can do to fix this short of a rebuild.
Thanx for any help you can give!
Robert
Old 12-13-2008, 08:00 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Remove the pan and inspect. I would say you have a broken hard part. I have taken 4 transmission apart this week, and all 4 had broken planetary gear set. Which was causing no reverse or 2nd, 3rd and 4th gears.
Old 12-20-2008, 07:39 PM
robolama5's Avatar
robolama5
Unhappy Transmission PO734,PO700
Well dropped the pan and I have chunks of metal .Pulled the transmission apart and yep the planetary gear not only let go but it exploded!
Quick Reply: Transmission PO734,PO700
