1999 dodge ram losing power
Old 12-22-2008, 07:44 PM
dave29989's Avatar
dave29989
dave29989 is offline
i have a 2002 ctd 167,000 miles 4x4 auto my truck was doing the same thing to a point what would happen is i would be driving and all of a sudden the truck would like shut down but the engine would still be running but u could put the pedal to the floor and nothing would happen it turned out to be the injector pump
  #22
Old 12-29-2008, 06:49 AM
rnjones's Avatar
rnjones
rnjones is offline
i have a 1999 dodge 3500 diesel i lost power whie towing my rv i was told by a mechanic that i need a fuel pump and a injector pump . it seems to run okay while not towing thank you
  #23
Old 06-21-2011, 11:21 PM
Sandman777's Avatar
Sandman777
Sandman777 is offline
Default 1999 dodge low power
Hi
I have a 1999 Dodge Ram 3500 Diesel and when i tow my trailer up hill i suddenly run out of power, the peddle is all the way down an there is no power. I pulled over for 5 min and left the engine running , I then pulled away and had no other problems. What could cause this?
I have a Jake brake I'm not sure if that might Have something to do with it.
The engine temp was around 250f
Sandman777
  #24
Old 06-21-2011, 11:26 PM
Sandman777's Avatar
Sandman777
Have you tried towing after you replaced the parts?
  #25
Old 12-14-2011, 02:30 AM
Jmack's Avatar
Jmack
Jmack is offline
I have same problem "kinda" although it happens whenever I use the cruise control when I slow down and drive off of cruis control mystery happens and I loose treddle control but i regain it after 30 seconds or there abouts. also the check engine light comes on. just saying it's being a mystery hiccup. been looking into it cautiously because i don't want to just go throwing parts at it I have a few other things going on as well that completely have me baffled as well.
Quick Reply: 1999 dodge ram losing power
