Hydro Boost Leak!
Old 11-24-2008, 12:15 PM
Rockdude's Avatar
Rockdude
Rockdude is offline
Default Hydro Boost Leak!
Hi guys, its been awhile.
Ok, it looks like I have a leak from a small hole (weep Hole?) on the bottom side of my Hydro Boost. I put some lucus stop leak in the power steering fluid with no results. Can I just plug this hole and forget about it, or is this hole sever a purpose I don't know about?
Trying to find a patch without spend the BIG bucks to replace the Hydro Boost.
Old 11-24-2008, 08:16 PM
High_On_Diesel's Avatar
High_On_Diesel
High_On_Diesel is offline
The leak would indicate that you have a seal leaking. Of course. Putting anything over the hole would stop it temporarily....maybe a few hundered miles. Best thing to do, if you are mechanically inclined, is to either rebuild the unit yourself, or buy a reman part and play parts changer. Then there's always the big bucks way....the dealer!
Old 11-25-2008, 04:48 PM
Rockdude's Avatar
Rockdude
Rockdude is offline
I guess I will break out the JB weld and see if I can stop the leak.
Old 07-08-2022, 07:13 PM
qmulley's Avatar
qmulley
qmulley is offline
how did it hold I re sealed mine and it still leaks from hole
Old 07-09-2022, 09:15 AM
HeyYou is online now
Received 3,164 Likes on 2,918 Posts
14 year old thread????
Quick Reply: Hydro Boost Leak!
