2002 four wheel drive issue
Old 11-21-2008, 08:54 PM
trelfazz's Avatar
trelfazz
trelfazz is offline
Smile 2002 four wheel drive issue
hey guy's, I've got a problem.
winters here and the other morning I flipped the switch(****, what ever its called) to put it in 4 high and nothing happened. No light on the switch, no four wheel drive. So i thought ok fuse is out, checked it, all fuses are fine. I get no warning lights on the dash and no error codes from the ecs. Durango drives fine it just wont go into 4x4. I can flip the **** all over the place an nothing happens.
Can someone maybe point me in the right direction cause I'm lost and really miss 4x4?
Thanks
Old 11-21-2008, 11:08 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
check the wire connections on the tcase, but you might have a bad module on the tcase(im not sure what its called, you should be able to do a search for this problem and find the answer), or it could possibly be a bad switch if non of the lights on the switch come on (is the green 2wd light on when you start the truck?)
Old 11-22-2008, 10:23 PM
n8ech's Avatar
n8ech
n8ech is offline
TF:
Try a battery disconnect reset. Remove the neg terminal, then depress the brake pedal for a minute, then reconnect. If this does not work, if the fuses are all good, and you can not hear any noises below when moving the switch, I think you have a bad TCCM. That would be transfer case control module.
This is located under the dash behind/beside the hood latch handle. You can find them in boneyards for less than $100, and I think a new one is closer to $400.
Don
Old 11-23-2008, 03:18 PM
trelfazz's Avatar
trelfazz
trelfazz is offline
no the green light does not come on, is there a way to check if the switch is bad?
Old 11-23-2008, 03:29 PM
Mean Green's Avatar
Mean Green
Mean Green is offline
You can test the voltage drop across the switch if you have a meter. It should be .1 or less. You can also set the a meter to Ohm's and hit the switch to ensure you have continuity. No power can be flowing for an ohm test though and an ohm test can lie.
Old 11-25-2008, 09:00 AM
n8ech's Avatar
n8ech
n8ech is offline
TF:
I really think your switch is ok. While it is the cheaper and easier repair, they don't get used much. Also, I would think you have have some lighting on in one of the positions if you had power to the switch.
My money is on the TCCM.
Don
Quick Reply: 2002 four wheel drive issue
