Remote Start by Autopage rs-610 plus Install Help
Old 11-14-2008, 12:38 AM
Poisonette's Avatar
Poisonette
Poisonette is offline
Question Remote Start by Autopage rs-610 plus Install Help
We pulled this off of our 99 Durango. It was on it when we got it. We want to put it on our 2005 Ram 1500 Quad-Cab.
We've got the install instructions which gives the wiring diagrams for the module, but we need help finding the corresponding wires in the truck. Our Hayes manual isn't helping much.
The instructions list 6 different power door lock senarios and how they operate. The Hayes didn't help in telling us how they work on the truck. The instructions say to tie the blue and green wires into the Locking Master Switch and Door Lock Relay Wires.
Which of the following is on our 05? (sorry for all caps, copied & pasted)
NEGATIVE TRIGGER DOOR LOCK SYSTEM
POSITIVE TRIGGER DOOR LOCK SYSTEM
5-WIRE ALTERNATING DOOR LOCK
2 STEP DOOR UNLOCK WIRE CONNECTION FOR 5 WIRE ALTERNATING DOOR LOCKS
2 STEP DOOR UNLOCK WIRE CONNECTION FOR GROUND SWITCHED DOOR LOCKS
2 STEP DOOR UNLOCK WIRE CONNECTION FOR POSITIVE SWITCHED DOOR LOCKS
Also need to know the following wire colors:
+12v = Key Switch
Ignition 1 Output = +12v in Start or Run position
Ignition 2 Output = +12v in Start or Run position
Parking Light Relay Output = Parking light wire headlight switch
I would attach the PDF instructions, but they're too big.
Quick Reply: Remote Start by Autopage rs-610 plus Install Help
