What causes P0171/P0174 Lean Bank 1/2?
Old 11-12-2008, 08:16 PM
Hawke's Avatar
Hawke
Hawke is offline
Default What causes P0171/P0174 Lean Bank 1/2?
I ran this code at Advanced the other day. Does anyone know what could cause this? The only indications I have of a problem from the truck, besides the codes, is the idle fluctuating +/-200 RPM on start up and sometimes dying at idle when engine is still cold. The check engine light goes out every once in a while but is on most of the time.
Old 11-12-2008, 10:50 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
A vacuum leak, clogged fuel filter or weak fuel pump.
Old 11-21-2008, 10:00 PM
DodgeAdvisor's Avatar
DodgeAdvisor
DodgeAdvisor is offline
If the PCM multiplies short term compensation by long term adaptive and a certain percentage is exceeded for two trips, a freeze frame is stored, the MIL illuminates and a trouble code is stored. Two Trip Fault. Three good trips to turn off the MIL
Old 11-21-2008, 10:36 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
on my ford explorer it was an intake leak.
Old 11-21-2008, 11:24 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Real common codes with a MAF system and a vacuum leak.
I can't believe that Dodge still uses the outdated map sensor system. These trucks would gain more from CAI's, exhaust mods, cams and heads if they had a MAF to measure the extra airflow.
Old 08-16-2009, 12:28 PM
karl918's Avatar
karl918
karl918 is offline
Default 1996 neon p0171
I keep getting a p0171 code (lean bank 1) on my 96 Neon. I've changed the air filter and the O2 sensor and I've checked for vacuum leaks, but the CEL keeps coming back on, giving me the same code. What else could it be?
Karl918
Old 06-04-2014, 03:41 PM
decapitateobama80's Avatar
decapitateobama80
decapitateobama80 is offline
Default Help
Can someone pls tell me what is going on . i have a 97 Intrepid . codes r PO171 and PO174 . i put fuel filter , spark plugs , , was running good but hard time starting
Old 06-05-2014, 09:52 AM
readyakira's Avatar
readyakira
readyakira is offline
If you don't visually seem a vacuum leak you can try spraying some carb cleaner around the top of the engine and listen for changes in rpm. Of course if ya have a scanner you can watch the short term fuel trims for changes when doing this. Lean Codes are usually an air leak in the intake portion of the engine. Rich codes are usually misfiring spark plugs or stuck injectors.
Old 06-05-2014, 09:53 AM
readyakira's Avatar
readyakira
oh. Idle air could cause a lean code too... But, I am not sure if your engine has one.
Old 07-13-2018, 04:32 PM
erlupo35's Avatar
erlupo35
erlupo35 is offline
I get codes p0171 p0174 and po157. On my 08 dodge 1500 sxt 3.7. I changed all 4 o2 sensors, spark plugs, air filter, map sensor. Cleaned the sensor in the intake box, then I found a tube coming from the air filter box goin to the back of the engine that was dry rotted and cracked. I changed the little hose and still am popping the codes???? IAC?? Maybe im gonna change it and ill let ya know what happens!
Quick Reply: What causes P0171/P0174 Lean Bank 1/2?
