2003 Dodge grand caravan brake and ABS light staying on?
Old 11-09-2008, 11:50 AM
kdk786's Avatar
kdk786
kdk786 is offline
Default 2003 Dodge grand caravan brake and ABS light staying on?
I have a 2003 Dodge grand caravan and the brake light and abs light are on. I scanned the van with OBD2 scanner and nothing came up. I even reset the codes hoping that it would fix it, but no change. Light is still on. The van has new front brakes and rotors. Has been working fine after new brakes were installed. The van was sitting for a while (about 2 months) and the battery died. When I revived the battery I believe this problem with the lights began. Does something need to be reset or is something else the problem. Please advise and thanks in advance.
Old 11-09-2008, 03:45 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Disconnect the battery for 5 mins and hook the cables back up. also ck ypur fluid level too.
Old 06-27-2010, 05:12 PM
06HEMI4X4's Avatar
06HEMI4X4
06HEMI4X4 is offline
Yes those MIL will light if your fluid is low or the level sensor on master cyl is bad. I just recently had and issue with my ram where the brake light switch was out of adjustment keeping the brake light on and the ABS and Brake MIL where staying on. As soon as I adj switch and got brake lights to go off MIL went off.
Quick Reply: 2003 Dodge grand caravan brake and ABS light staying on?
