Broken Latch On Quad Cab
Old 11-04-2008, 12:06 PM
Ninety5PoloZ's Avatar
Ninety5PoloZ
Ninety5PoloZ is offline
Default Broken Latch On Quad Cab
I cannot get the rear passengers side door to open on my 98 sport. I pulled the door panel off and all of the hardware was still hooked up, both metal rods were straight and moving with the handles. The upper latch will open and let the top of the door move out a little, but the lower latch is borken or something.
I have removed both rods and both handles and tried to pull down on the top latch and pull up on the bottom latch to make the door open so I can replace what is needed, but I can't get the damn lower latch to open. And I don't know if I can get it open without ruining the door.
Does anyone have any tips to get it open whenyou can't get to anything? I have thought about taking a sawzall and cutting the lower latch off, but I don't think it can be done.
But any help would be appreciated.
Old 11-04-2008, 07:46 PM
01DodgeRam1500's Avatar
01DodgeRam1500
01DodgeRam1500 is offline
same thing happened to my ram but it was the driver's side door
Old 11-04-2008, 08:15 PM
PurplDodge's Avatar
PurplDodge
PurplDodge is offline
The same thing happend to mine too! EKK!
Old 11-05-2008, 01:39 AM
Ninety5PoloZ
So........What do you do? Just leave it or is there a solution?
Old 11-06-2008, 01:51 AM
Ninety5PoloZ
Priced the latch from the dealer and its $88, thats just rediclious for a little damn latch, but I gotta get the old one out first. I'd really like to be able to use all 4 doors if they are there, so if anyone knows a secret to get the bastard out I'd really like to hear it
Old 11-06-2008, 02:32 PM
ice01's Avatar
ice01
ice01 is offline
Default Door Problem here also!!
Hey my 01 Ram QC passenger rear door wont open from the inside, it does open if you try the outer handle. I have not tore into it yet but I ll let you know what I find if anything. Not much help but as I heard on here before misery loves company
Old 11-06-2008, 03:47 PM
simpsonna's Avatar
simpsonna
simpsonna is offline
Yeah my rear passenger door won't open from the inside either. I haven't figured it out yet for lack of time. My rear drivers side stopped working inside and out once but it was already open and I was messing with it I believe I pulled a rod juuuuust right and was able to get it back together.
The way these handles and latches are put together is crazy.
Old 11-11-2008, 04:01 AM
Ninety5PoloZ
If it doesn't open from the inside its probably just the cable. But I have the door panel off and all of the guts out, but I cannot get the damn bottom latch to release. I can pull the top of the door out a little bit, but the bottom latch won't budge. I have soaked it down for a week and still nothing. The latch moves up and down like normal, but the mechanism is not working like it should. If the truck has 4 doors I'd like to be able to use them all.
Old 11-12-2008, 10:00 PM
guitarking135's Avatar
guitarking135
guitarking135 is offline
grease everyhting really good
Old 11-13-2008, 02:36 AM
Ninety5PoloZ
Ok then what? I have been soaking the thing down with PB Blaster for 3 weeks and nothing has happened. The lower latch is broken and does not operate correct, so greasing it will really do nothing. I need a solution to get the latch out without replacing the rear door.
Quick Reply: Broken Latch On Quad Cab
