Engine taking a long time to turn over + p0440 and p0441
Old 10-13-2008, 09:45 PM
jagerfish's Avatar
jagerfish
jagerfish is offline
Default Engine taking a long time to turn over + p0440 and p0441
Hi,
Lately my '03 Neon has been taking longer than it should to start - spends about 5-8 seconds trying to turn over before starting (which is a long time when you think about it). My check engine light has also come on, telling me the codes p0440 and p0441. I know these basically mean either the gas cap is bad or there's a leak in a hose somewhere.
My question is - could the two problems be related? Could this cause my car to take so long to start?
Any other comments you have about this are also appreciated.
Thanks,
Old 10-13-2008, 11:29 PM
Izero's Avatar
Izero
Izero is offline
try a new gas cap all together first off... then do a tune up (new plugs [IRIDIUM] and wires) then let us know whats up
Old 10-15-2008, 11:34 AM
jagerfish's Avatar
jagerfish
So the two items are not related?
Old 10-15-2008, 01:38 PM
Izero's Avatar
Izero
Izero is offline
oh no they are indeed related but usually its just b/c the gas cap isn't sealing correctly... or you are getting a bad spark...
Old 10-16-2008, 03:18 AM
Exubus's Avatar
Exubus
Exubus is offline
U wiykd sat bad spark... a bad connection through the coilpack, wires, plugs, etc. Or possibly even a bad MAF sensor, or better yet a bad O2 sensor or two... but even that is suspect for start-up.
A loose gas cap can cause the code, but not at startup. Your ECU will catch it, but it should not affect your starting performance whatsoever.
Old 10-18-2008, 11:09 AM
tooslow's Avatar
tooslow
tooslow is offline
this is a evap code it is probly the evap purge selenoid it sits under your brake booster against the firewall.
Old 10-19-2008, 04:01 AM
et_agus's Avatar
et_agus
et_agus is offline
Lol, I had the exact same codes! Then one day I noticed the cel was gone. I checked for the code and it was still there though. If your car is under 100,000 miles, the emissions devices should be covered by Dodge by law.
Anyway, I got lazy about it, and didn't do much about it. the cel would show up for a couple hundred miles, then go away for another couple hundred (but still showed the code). Recently I checked for the codes, and it just said dONE. they went away.
Quick Reply: Engine taking a long time to turn over + p0440 and p0441
