Trouble code help
Old 09-11-2008, 11:05 PM
norcalvp's Avatar
norcalvp
norcalvp is offline
Default Trouble code help
My dad just purchased an 01 Chrysler town and country. It's running very rough, and very rich. We removed both O2 sensors and the rear sensor was physically melted. Put in a new sensor and now are getting some trouble codes.
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0118 Engine Coolant Temperature Circuit High Input
P0122 Throttle Position Sensor/Switch A Circuit Low Input
P0204 Injector Circuit Malfunction - Cylinder 4
P1478 Battery Temp Sensor Volts Out of Limit
I'm guessing that at least part of our problem has to do with the 5V. We measured the pins on the TPS connector with the TPS disconnected We're getting .3V, .04V, 3.85V. I'm guessing that the last one should be at least 5V..
Any suggestions.
Steve
Old 09-12-2008, 07:26 PM
norcalvp's Avatar
norcalvp
norcalvp is offline
Did some more troubleshooting today, and from what I can tell the problem may not be any of the sensors listed above. The battery voltage is fluctuating wildly. When it's running good, the voltage is rougly 10-11V, When it starts to fall on it's face, the voltage drops down to 7-8V. I've seen it go as low as 4V. But then once the car dies, it goes right back up to 12V.
Anyone have any wiring digrams for the Charging circuitry?
Old 09-12-2008, 10:56 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Send me an email so I can send you some pdf files for your codes.
Old 09-13-2008, 02:28 PM
norcalvp's Avatar
norcalvp
norcalvp is offline
I didn't see an E-mail in your profile, so I sent A PM.
Thanks
Steve
Old 06-26-2011, 06:21 PM
mattheweldred1's Avatar
mattheweldred1
mattheweldred1 is offline
what is code p0406 egr. sensor A circuit high and where is it on the 2005 town & country van
Old 06-27-2011, 01:51 PM
master tech
Welcome to DF
The code means you have either a EGR circuit open or the EGR has failed and causing a high circuit code.
Old 07-04-2011, 08:21 PM
jerryajay's Avatar
jerryajay
jerryajay is offline
I have a 2008 grand caravan it is running rough and I got a p0406 code what is the problem and what this to code mean.
Quick Reply: Trouble code help
