What type of fluid goes in the transfer case
Old 08-27-2008, 11:36 AM
mcss8541's Avatar
mcss8541
mcss8541 is offline
Default What type of fluid goes in the transfer case
Hello everyone, I will by changing my transmission this weekend and have started getting all of the fluids needed for the task. Since the transfer case will be coming out I thought it a good time to change the fluid, what type and brand would you recommend? I have a 98 1/2 ton 4X4 Sport with a 5.9L V-8. I am running 35 x 17 with 4:56 gears. Thaks!
Old 08-27-2008, 12:33 PM
94Beater's Avatar
94Beater
94Beater is offline
Automatic Transmission Fluid - about 2 quarts.
I use Mobil 1 Sythetic ATF
Old 08-27-2008, 12:51 PM
mcss8541's Avatar
mcss8541
mcss8541 is offline
thank you my friend will do
Old 08-27-2008, 01:36 PM
hometheaterman's Avatar
hometheaterman
hometheaterman is offline
ATF+4 so that if if the seal goes and it mixes with the transmission fluid nothing gets harmed. Use the same as in the transmission and imo and lots of others ATF +4 is by far the best way to go for these transmissions. Wayne from APS said he also recommends it so that's all I will run.
Old 08-27-2008, 08:54 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
ATF +4 in t-case and auto transmission. its a synthetic.
tip #1. the recesses hex plug is 10mm, not 3/8. caution a 3/8 might strip it. if you don't have a 10mm hex, use a bolt head.
tip #2. remove the fill plug first and the drain plug second. that way if the fill plug strips your not stuck.
don't ask me how i know this.
Old 08-28-2008, 08:33 AM
mcss8541's Avatar
mcss8541
mcss8541 is offline
Talking
Thanks D as usual you always come through for me
Old 08-28-2008, 08:38 AM
mcss8541's Avatar
mcss8541
mcss8541 is offline
thanks for all the help now if i can only get my best friend to find time to help me do this. He has all the impact tools at his house. I got in this predicament by being towed home ( 60 miles) at an avg speed of 60mph with the truck tranny in neutral but NOT THE TRANSFER CASE. I know idiotic. When I dropped the trans pan it was like I was panning for gold or in this case metal shaving in which there was ALOT.
Old 08-28-2008, 08:59 AM
95laRAMie's Avatar
95laRAMie
95laRAMie is offline
i agree with the ATF+4 but what about for a manual trans. like i got in my 95 1/2ton 4WD 5.2L?
Old 08-28-2008, 01:25 PM
Redneck2345's Avatar
Redneck2345
Redneck2345 is offline
80/90 gear oil in the manual tranny
Old 08-28-2008, 01:58 PM
95laRAMie's Avatar
95laRAMie
thanks, im gonna change it soon, as well as front/rear diff fluids
Quick Reply: What type of fluid goes in the transfer case
