Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
Resetting check engine light ?
Old 01-29-2005, 11:35 AM
carlsturm's Avatar
carlsturm
carlsturm is offline
Default Resetting check engine light ?
Is there an better way to turn-off check engine light than disconnecting battery?
Old 01-29-2005, 12:17 PM
Fiddle Player's Avatar
Fiddle Player
Fiddle Player is offline
Default RE: Resetting check engine light ?
I took my vehicle to the dealer and they manually turned it off.
Old 01-29-2005, 12:19 PM
carlsturm's Avatar
carlsturm
did the dealer charge you ?
Old 01-29-2005, 12:28 PM
Fiddle Player
No because I'm still under warranty which is nearly up. I know a co worker of mine..who drives a ford escort though...had a bad bulb in hers and it caused it to keep her engine light on. A sensor could be bad also. Has your vehicle been giving you any problems?
Old 01-29-2005, 01:27 PM
carlsturm's Avatar
carlsturm
The truck hasn't given me any problems, but I just purchased it and the check engine light appeared shortly after I filled with gas. Thought it was loose gas cap but it's clicking tight.
If a check engine light appears due to a loose gas cap - does it "self heal" after the gas cap is tightenedd?
Truck is 98 Dak 5.2/5 speed.
Old 01-29-2005, 02:52 PM
Fiddle Player
I know on my truck I have a light, that has never come on yet, that'll come on if my gas cap is not on or tightened. Sounds to me something is triggering the sensor therefore giving you a false reading making your truck think there's something wrong when there really isn't.
Quick Reply: Resetting check engine light ?
