2005 Grand Caravan Power Seat stuck
Old 08-11-2008, 07:49 PM
Sierras's Avatar
Sierras
Sierras is offline
Junior Member
Default 2005 Grand Caravan Power Seat stuck
Hello,
I have a 2005 Grand Caravan with a passenger seat problem.
The seat is in the fully forward position and it will not go back.
When I press the button to move the seat back, you could hear the motor move. And you could also see that the left side of the seat track starts to go back. But the right side just stays stuck. So the seat just seems to rotate a little instead of moving back.
I checked if there was anything in the track - but the track is clear. Also, the wiring does not seem to be damaged either.
Anyone know if this is an easy fix? I still have an extended warranty on this, but it would cost a $100 deductible (I think). So I'm not sure if the parts to fix this would cost more than my deductible.
Any advise would be appreciated. Thanks...
Old 08-11-2008, 08:48 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
The track motor maybe binding, if you look under the seat and don't see anything jamming motor. Then you may want to take it in.
Quick Reply: 2005 Grand Caravan Power Seat stuck
