Where is the Voltage Regulator?
Old 08-06-2008, 05:26 PM
cmplant3210's Avatar
cmplant3210
cmplant3210 is offline
Junior Member
Default Where is the Voltage Regulator?
I called the local dealer and they said that the voltage regulator is located in the computer. Is this right? Is it not on the alternator? I ask because my car idles at around 600rpm and it's ticking me off. I thought maybe i needed a new voltage regulator. I've had the alternator checked and they said that was fine.
Old 08-06-2008, 08:08 PM
bone33's Avatar
bone33
bone33 is offline
its in the PCM
Old 08-07-2008, 01:24 AM
03neonRT's Avatar
03neonRT
03neonRT is offline
Nope the PCM controlls voltage regulation.
As for your idle, most Neon's idle at 600-700 RPM and voltage has nothing to do with it.
If you want a higher idle then drill a tiny hole in the butterfly plate on the throttle body. The larger the hole the higher the idle...
Old 08-08-2008, 03:51 AM
Exubus's Avatar
Exubus
Exubus is offline
Hmm, some pre-'90s cars had adjustable voltage regulators on the alternator... a lot of cars after that had fixed voltage regulators built in to the alternator... I wonder why DCX would put in IN the PCM? Fear of "tampering" of it by the owner?
Old 08-08-2008, 08:55 PM
Parts/Service's Avatar
Parts/Service
Parts/Service is offline
The Electronic Voltage Regulator (EVR) is not a separate component. It is actually a voltage regulating circuit located within the Powertrain Control Module (PCM). The EVR is not serviced separately. If replacement is necessary, the PCM must be replaced.
Old 08-08-2008, 11:14 PM
Exubus's Avatar
Exubus
Exubus is offline
Like I said... it sucks that the EVR/PCM is combined. One less DIY repair for the Neon to add to the service list lol...
Old 08-14-2008, 09:40 PM
cmplant3210
Junior Member
Thank you all for your help! Would someone be able to tell my where the throttle body gasket is located? I'm wondering if that fell off when I put my cold air intake on and im having problems finding a site that shows where it is.
Quick Reply: Where is the Voltage Regulator?
