1st Gen Intrepid 1993 through 1997 Intrepids
1997 DODGE INTREPID WON'T START
Old 07-30-2008, 08:02 PM
fred d's Avatar
fred d
fred d is offline
Default 1997 DODGE INTREPID WON'T START
WE WERE PULLING IN TO THE DRIVE WAY THE OTHER AFTERNOON AND THE CAR DIED AND WON'T START. IT STILL TURNS OVER. THE BATTERY IS NEW. THERE IS NO SPARK WHEN YOU CRANK IT OVER. A) HOW CANI CHECK TO SEE IF THE COIL IS WORKING B) AND HOW CANI CHECK THE CRANK SENSOR. THEY ARE THE ONLY THINGS THAT COME TO MIND. IF ANYONE HAS ANY IDEAS I WOULD BE GREATLY APPRECIATED.
Old 07-30-2008, 10:10 PM
kurts2's Avatar
kurts2
kurts2 is offline
Default RE: 1997 DODGE INTREPID WON'T START
Do the key trick and tell me the flash codes (turn key from off-to-run (NOT START) three times, on the third time, the check engine light will blink two digit codes. The last code is 55).
Old 08-05-2008, 08:05 PM
fred d's Avatar
fred d
fred d is offline
tried the key trick and nothing happened. I did check the fuse block under the hood and found that the engine controller fuse was blown. I replaced it and that one went as well. Does that help at all? And resently I replaced the starter. Not sure if that would mean anything or not.
Old 08-10-2008, 05:22 PM
ralphael101's Avatar
ralphael101
ralphael101 is offline
Ok, question first. Does your check engine light come on when you turn the key on? If not, you probably have a wire touching(grounding out) on your engine or something. Thats why your fuse keeps blowing when you put a new one in. Try pulling your main wire harness away from the engine and tie it up. Also check the other wires. Then put a new fuse in and see if it starts. If you now have a lit check engine light but the car still will not start, change the pcm. This means that it got shorted out from the wire touching. The fuse couldn't protect it but so many times. You can pick one up from any junk yard pretty cheap to see if im right. U-pull it junk yard are the best in this case. Probably about $20. Take the numbers off of yours to make sure you get the same one. Let us know how you make out. This helps this site alot. Good luck
Old 09-04-2008, 01:52 PM
fred d's Avatar
fred d
fred d is offline
Default It's Fixed
I wasn't able to figure it out so I put it in the shop. They found that the fuse for the ecu blew. They don't know why. They replaced it and everything has been working fine ever since.
Old 07-17-2010, 02:26 PM
Garyaka1gardner@aol.com's Avatar
Garyaka1gardner@aol.com is offline
I had a similar problem with mine and my flash code was 1255 what does that mean
Old 07-19-2010, 12:20 AM
kurts2's Avatar
kurts2
kurts2 is offline
12 is common, it means the bat was disconnected within the last 50 starts. This w/n trip a light and it could be corrosion on the bat. That may be why you can't start though if you are having turn over problems.
55 means you have reached the end of the codes stored. So all in all, they mean nothing too much.
Old 07-20-2010, 04:13 PM
Default Thanks
Thanks guy thats what it was. saved time and money
Old 05-02-2012, 05:22 PM
Logan Taylor's Avatar
Logan Taylor
Logan Taylor is offline
Default 95 Intrepid v6 3.5 wont start
Yesterday I was coasting to a tollbooth and my car slightly backfired "puff, puff" and then died and will not restart. It turns over but won't start. Changed coil pack and still will not start I smell gas when I try to start it so I don't think it's the fuel pump or the fuel filter. Checked all fuses and relays and all were good but changed anyway. If you have any ideas that I could try please let me know. I don't know if you can call me so my # is 267-720-7094. Thank you
Logan
Old 08-01-2012, 09:04 PM
Cougar1068's Avatar
Cougar1068
Cougar1068 is offline
Cool
My son was driving my '97 3.5 the other day when the water pump sprung a leak, replaced it and made sure the timing belt was undamaged but now it won't start. Replaced battery cause it was cranking at half speed, no help. Also replaced the coil just in case. Starter is only 6 months old. Anyone know why it cranks so slow and won't start?
Quick Reply: 1997 DODGE INTREPID WON'T START
