Old 08-05-2015, 09:00 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
AC Blows Hot at Idle, Cold when moving?
Old 07-27-2008, 04:12 PM
ramdaddy's Avatar
ramdaddy
ramdaddy is offline
Junior Member
Default AC Blows Hot at Idle, Cold when moving?
My 2002 1500 Ram's AC is blowing hot air when I'm stopped andengine idlingand cold air when I'm moving at speeds higher than 20 mph. Anybody know why?
Old 07-27-2008, 06:21 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
SeVeReDiStOrTiOn is offline
Default RE: AC Blows Hot at Idle, Cold when moving?
Classic symptom of the A/C condensor fan not working. Open the hood and you'll see a mini radiator looking thingon the right with an electric fan behind it...the fan motor is probably shot. That fan should be on the whole time the a/c is on..
Old 07-27-2008, 06:33 PM
iwa2002's Avatar
iwa2002
iwa2002 is offline
2x... before changing out e-fan. check relays..
Old 07-28-2008, 03:05 AM
abarmby's Avatar
abarmby
abarmby is offline
X3 but before anything else, check the AC condenser fan fuse in the fuse box.
Al.
Old 08-16-2008, 08:30 PM
ramdaddy's Avatar
ramdaddy
ramdaddy is offline
Junior Member
Installed new condenser fan and ac blows cold air at all times!
Thanks fellows for the help!
Here are some tips for others needing to replace a condenser fan:
Condenser Fan part only price quotes:
Dealer: $187
Ebay (Heavy Duty Radiaters, Radpro, ebay user hmm20011): $90 delivered from Sarasota, FL
Installation:
Remove the 2 bolts from top of fan housing attached to truck frame.
Pull condenser and fan housing up and out together. (no need to discharge ac, leave ac hoses attached to condenser)
Remove the 4 screws from the fan housing. There are 2 on each side.
You will need to cut an area of the fan housing that's will alow you to remove condenser from fan housing where the top ac plug is attached.
Unplug fan motor.
Remove old fan housing from condenser.
To install the replacement, repeat the previous steps backwards.
Old 06-15-2010, 06:43 PM
Durango_Dude22's Avatar
Durango_Dude22
Durango_Dude22 is offline
Default A/C blows hot
Thanks for the info - I started with the cheapest fix - a $10 relay. A/C works like a champ! The old one was junk, you could see it was visually burned - shot
Thanks all,
Old 06-29-2010, 10:01 PM
Atticus_6147's Avatar
Atticus_6147
Atticus_6147 is offline
Hey I just want to give props to Ramdaddy for his instructions. I just replaced mine and your way saved me $80 because I didnt need to have my system drained and refilled. Took about 30 minutes. Thanks man.
Old 06-29-2010, 10:10 PM
03MopaRamman's Avatar
03MopaRamman
03MopaRamman is offline
Good Info, My Ram is ice Cold, But the Wifes PT Cruiser acts that way when her car is stationary, will have to check it out.
Old 08-08-2011, 10:13 PM
revkevin's Avatar
revkevin
revkevin is offline
ramdaddy - thanks for the tips. altering the fan housing to get around having to mess with the AC lines was a brilliant move.
Old 08-15-2011, 10:33 PM
BigBlue16's Avatar
BigBlue16
BigBlue16 is offline
Default YouTube Video
I know this has already been answered, but this video and the pt 2 on the same YouTube link walked me straight through the same problem and solution.
http://www.youtube.com/watch?v=x1t4r...layer_embedded
Besides, I am a visual learner.
Quick Reply: AC Blows Hot at Idle, Cold when moving?
