evap leak
Old 07-15-2008, 06:18 AM
cmares's Avatar
cmares
cmares is offline
Default evap leak
Does anyone know how test the evap system? I have an engine codeP 0455 large leak detected. I don't know where to start.
Old 07-15-2008, 05:21 PM
greenmachine's Avatar
greenmachine
greenmachine is offline
Default RE: evap leak
Drive around for a bit. Stop and take off the fuel cap. If the fuel cap does not purge then you definetly have a leak. You need to change your fuel cap. If that does not fix the problem then you need to replace the rubber hoses at the canister. These are located in the engine compartment.
Old 07-15-2008, 06:21 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Don't mean to jack your thread , But hey greenmachine? Buy purge you mean hear air swoosh when the cap is opened correct? I never hear anything since I've owned it for 6 years and I don't have any codes. Is it possible the cap is bad ?
Old 07-16-2008, 02:14 AM
Sixtysixdeuce's Avatar
Sixtysixdeuce
Sixtysixdeuce is offline
Ideally, you use a smoke machine to test for evap leaks. Since most guys don't have that little $1000 piece of equipment, all you can do is physically inspect fuel cap, solenoids, charcoal canister and all connecting hoses inch by inch. Bad fuel caps (or loose, missing) are the #1 cause for evap leak DTC's, but I've seen plenty of cracked lines and melted purge valves. Also see lots of stuck vent solenoids in dusty areas.
Old 07-16-2008, 03:11 AM
greenmachine
ORIGINAL: zman17
Exactly
Old 07-16-2008, 05:43 PM
krs7272's Avatar
krs7272
krs7272 is offline
Just fixed my p0455 code that I've had for going on 3 yrs yesterday. For some reason there is a hose that does a 180 out of the canister and connects to a fitting in the frame rail. You can't see it but upon feeling the line I found it split wide open. Replaced code gone today. Actually I also had a p0138 O2 code but lite off today either way.
Old 07-16-2008, 08:48 PM
EricCartman's Avatar
EricCartman
EricCartman is offline
ORIGINAL: krs7272
x2
I would check the vacume hoses under the hood for cracks first (since they are easy to access).
If they look good - no problems, move to the Evap canister. It is easy to pull down and check the hoses. If you are throwing a big leak code though... you should be able to feel it.
I was about ready to give up on my evap leak and pay a shop. I'm glad I check the canister connections. Cost less than 10 bucks in parts and an hour of my time to fix. I feel much better knowing that I fixed it.
Good luck,
Cartman
Old 07-17-2008, 06:52 AM
cmares's Avatar
cmares
cmares is offline
Was your canister under the cab or in the engine compartment? I have a round and square canister under the cab.
Old 07-17-2008, 08:52 AM
krs7272's Avatar
krs7272
krs7272 is offline
Passenger side rear of cab square.
Old 07-17-2008, 01:19 PM
EricCartman
ORIGINAL: cmares
That's it. Should be on the passenger side under the cab.
I just unbolted the bracket and took them off so that I could get a good visual inspection on them. It should only be 3 or 4 bolts.
Cartman
Quick Reply: evap leak
