Anti-Theft Switch or "Kill Switch"...Where to install?
Old 07-13-2008, 08:33 PM
Jobhater's Avatar
Jobhater
Jobhater is offline
Default Anti-Theft Switch or "Kill Switch"...Where to install?
I just got my truck a week ago and would like to install a switch to prevent the truck from starting (for anti-theft reasons). I've done this in the past through the wiring to the starter, the fuel pump, or through the fuse box. What are other options out there? Would a switch added to one of those possible places cause a problem on this truck (like freak out the computer)?
(Some of the vehicles I have done before: 2003 Dodge Dakota, 1992 Ford Thunderbird, 1988 Pontiac Grand Am, and 1976 Jeep CJ-5.)
Thanks
2003 Dodge Ram Laramie, 5.7L Hemi
Old 07-13-2008, 09:40 PM
Bensredram's Avatar
Bensredram
Bensredram is offline
Default RE: Anti-Theft Switch or "Kill Switch"...Where to install?
I'm thinking you could put a switch on the fuel injector circuit without causing problem.
Old 07-13-2008, 11:05 PM
PhotoRam's Avatar
PhotoRam
PhotoRam is offline
You could check out the directions for the install of a dash mount start switch. They show you which wire to interrupt to block starting completely.
Old 07-14-2008, 06:06 AM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Without the right chipped key, it won't run anyway.
Old 07-14-2008, 09:59 AM
xfeejayx's Avatar
xfeejayx
xfeejayx is offline
3rd gen Ram, Newbies
2003 might not have chipped key.
Old 07-14-2008, 10:27 AM
chefred112's Avatar
chefred112
chefred112 is offline
would it be just as easy to do a battery kill switch?
Old 07-14-2008, 12:19 PM
mmstar23's Avatar
mmstar23
mmstar23 is offline
thats what i was thinking. interupt the battery power with a switch, but if you think about it, you'll loose all your settings like in your radio and all of that, so i dont think that would work very well
Old 07-14-2008, 12:39 PM
truckin151's Avatar
truckin151
truckin151 is offline
Ive done it in my older trucks where you run one of the wires from the ignition (dont ask which one as I haven't done this in a few years but I believe it was a ground wire) to in my trucks case the turn signal. The idea is that in order to start the truck you had to switch the left hand turn signal on before you turn the key or it wouldn't start. Just having a visible switch is alright but there aren't to many places to hide one where its conviniant to you but hard for others find.
Old 07-14-2008, 12:43 PM
chefred112's Avatar
chefred112
i think you would lose time but not radio presets with a battery kill switch
Old 07-14-2008, 12:49 PM
CarGuyOhio's Avatar
CarGuyOhio
CarGuyOhio is offline
If you want to install a switch I would put it in the hidden compartment if you have it. (Under the middle seat).
Quick Reply: Anti-Theft Switch or "Kill Switch"...Where to install?
