1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
6g72 engine swap
Old 07-11-2008, 02:02 AM
Beasty's Avatar
Beasty
Beasty is offline
Default 6g72 engine swap
ok ive been looking at different engines for a couple of weeks now but im not sure if it will work but i was looking at the specs for a 6g72 engine out of a 2000 galant. so basicly does anyone have advice on it?
Old 07-11-2008, 10:45 AM
bad venge's Avatar
bad venge
bad venge is offline
Section Moderator
Default RE: 6g72 engine swap
Is that the standard 3.0 ??? If so the write up is posted
Old 07-11-2008, 12:27 PM
Beasty's Avatar
Beasty
Beasty is offline
i dont think its standard im pretty sure every trans made for that motor is auto.... but i could be wrong
whats the post labeled i tried looking before i posted but didnt see anything interesting
Old 07-11-2008, 02:05 PM
bad venge's Avatar
bad venge
Section Moderator
Old 07-12-2008, 02:28 AM
Beasty's Avatar
Beasty
Beasty is offline
ok im alil drunk but lets see if i can get my question asked without confusion since i know ill forget in the morning...... that post bad venge showed me proved to my friends that i wasnt insane for wanting to put a 3.0 out of an eclipse in my car so thank you for that.... but what my actual question is the pistons on the stock 3.0 out of an eclipse cant hold the psi produced by forced air induction so what would anyone recommend for internal work on the block to hold the psi required for forced air induction?........
Old 07-12-2008, 04:10 PM
bad venge's Avatar
bad venge
Section Moderator
It holds up fine to forced induction there are tons of cars running ripp mods superchargers
Quick Reply: 6g72 engine swap
