CODE P0622 and VOLTAGE LIGHT ON
Old 07-10-2008, 10:00 AM
nicolastella's Avatar
nicolastella
nicolastella is offline
Default CODE P0622 and VOLTAGE LIGHT ON
Hi, when I turn on my engine the voltage light remain ON and I have the
P0622 code . After about 10 miles if I turn off and on again the engin the light remain off. The voltage with the engine on is around 13.6V. Someone know what cause this problem. Thank[/align]
Old 07-10-2008, 02:25 PM
kurts2's Avatar
kurts2
kurts2 is offline
Default RE: CODE P0622 and VOLTAGE LIGHT ON
An open or short in the field control circuit. It could be wire, the alt, or the PCM. If the condition goes away after running a bit (more than likley heat related), I'd go with one of the two components (alt/PCM). The alt is cheeper and easier to change so...I'd try that. Now if you are handy with a meter, go to the top of the sec gen fourm and you will find the "holy grail". Use the info to aid in troubleshooting.
You could also go to Auto Zone, and they can test your charging system in the car for free, however, this specific malfunction may not show up, as it's more of an optimimum charge issue.
Quick Reply: CODE P0622 and VOLTAGE LIGHT ON
