Timing Belt For Stratus Coupe 2.4L
Old 06-25-2008, 09:21 AM
degupo2's Avatar
degupo2
degupo2 is offline
Default Timing Belt For Stratus Coupe 2.4L
Just recently Ibought a 2001 Dodge Stratus Coupe SE 2.4L and now I thinking of replacing the timing belt. The previous owner cannot recall when andif he ever replace it. I now have 105,000 mile on it. I guess the question is when to replace the timing belt?
I appreciate any response. Thanks!
Old 06-25-2008, 12:12 PM
bad venge's Avatar
bad venge
bad venge is offline
Section Moderator
Default RE: Timing Belt For Stratus Coupe 2.4L
If it's the original you are overdue ..
Old 06-25-2008, 12:52 PM
degupo2's Avatar
degupo2
degupo2 is offline
I want to buy the part myself.Should I buy a timing belt or timing chain?
Old 06-25-2008, 05:33 PM
bad venge's Avatar
bad venge
Section Moderator
To my knowledge they are not interchangeable .... I thought they came with belts replace with same ... Tensioner and water pump too
Old 06-25-2008, 06:54 PM
nate_0022's Avatar
nate_0022
nate_0022 is offline
You need a belt, change the water pump along with it.
Old 06-26-2008, 05:21 AM
tacoboy's Avatar
tacoboy
tacoboy is offline
Sounds like you need to be a little more informed of just how big of a job this really is. It can be a PITA expecially if you don't have the tools. A manual (Hayne's or otherwise) is essential. If there are any doubts that you can do it yourself, have someone else who has done it help you or take it to a garage.
Old 06-28-2008, 12:53 PM
pearl01stratcpe's Avatar
pearl01stratcpe
pearl01stratcpe is offline
Should be changed at 60k miles, however many have worked well past that. I recommend getting it done, as its a crutial part. You will need the timing belt, water pump, and tensioner, and any related gaskets. ALL parts can be found at Advance Auto.
Quick Reply: Timing Belt For Stratus Coupe 2.4L
