TUNE UP COSTS?
Old 06-18-2008, 11:38 AM
NYPANAMA42's Avatar
NYPANAMA42
NYPANAMA42 is offline
Default TUNE UP COSTS?
Got a question for those of you in the know, because i've seen that things have changed over the years.....What is the average cost of a tune up? And what exactly does a tune up consist of?
Old 06-18-2008, 12:11 PM
xfeejayx's Avatar
xfeejayx
xfeejayx is offline
3rd gen Ram, Newbies
Default RE: TUNE UP COSTS?
not all that much really. spark plugs, wires, maybe coolant and trans if you are due. check a bunch of stuff. grease ball joints, check belts, hoses, maybe diff and transfer case fluids. don't know what the cost would be, but it will vary with how much you're getting/need done. the plugs and wires alone will run you over a hundred if you got them done somewhere.
Old 06-18-2008, 12:12 PM
xfeejayx's Avatar
xfeejayx
xfeejayx is offline
it should all be listed in your maintenance manual
Old 06-18-2008, 03:53 PM
KKYW Ram 7's Avatar
KKYW Ram 7
KKYW Ram 7 is offline
Plugs are absolutely horrible. 16 when you count the packs, +3hours of labor. nearly broke the bank on my last tune up.
Old 06-18-2008, 05:04 PM
xfeejayx's Avatar
xfeejayx
xfeejayx is offline
3 hours of labor?!!! wtf?
Old 06-18-2008, 05:19 PM
daytona1680's Avatar
daytona1680
daytona1680 is offline
ORIGINAL: xfeejayx
exactly what I was just thinking. lol.......For just new plugs and wires it will be about $100
Old 06-18-2008, 07:26 PM
NYPANAMA42's Avatar
NYPANAMA42
Now i don't feel so bad.....I guess some of you guys thought i was joking when i mentioned the price above....These charges are amazing.....
Old 06-18-2008, 09:10 PM
xfeejayx's Avatar
xfeejayx
xfeejayx is offline
just realized i got a coupon from local dealer for spark plugs, I think it was $100 or 109 installed. add on a set of wires (no added labor since they pull them anyway) and I figure $160-180 or so for everything with all mopar stuff. This is the dealer, mind you. It can be done much cheaper if you go to the right place, like your garage, driveway, or street in front of your residence.
I just stumbled upon this site: repairpal.com it seems fairly accurate at estimating repair/maintenance costs
Old 06-18-2008, 09:29 PM
rtmtrrdr's Avatar
rtmtrrdr
rtmtrrdr is offline
abuddy of mine has an '04 with 90,000 miles on it and he was quoted $600 for all of the above you had mentioned
Old 06-18-2008, 10:25 PM
KKYW Ram 7's Avatar
KKYW Ram 7
yeah mine has 90,000. I think the cost had mostly to do with the packs on top of the plugs...
Quick Reply: TUNE UP COSTS?
