2000 stratus won't start
Old 06-17-2008, 06:41 PM
GUANADON's Avatar
GUANADON
GUANADON is offline
Default 2000 stratus won't start
I went out to power the windows up after driving it home from work the other day and with it in accessary mode the driver side window went half way up and stopped. I tried to start it and there was nothin' doin'. So this is the deal when I turn the key to start only the fuel relay clicks and when I return the key to the run pos. the dash lights flash three times (don't know if that means anything). the fuel rail has pressure (replaced the fuel pump last summer). the fuses are all good both under the dash and the hood. the battery has a full charge. Any Ideas.
Old 06-18-2008, 01:15 PM
GUANADON's Avatar
GUANADON
GUANADON is offline
Default RE: 2000 stratus won't start
Also, with it in accessory mode the windows will go up but they pulse in very short bursts. Help
Old 06-18-2008, 01:59 PM
bad venge's Avatar
bad venge
bad venge is offline
Section Moderator
When you say "won't start " does it CRANK ???
Old 06-18-2008, 08:14 PM
GUANADON's Avatar
GUANADON
GUANADON is offline
No crank, just fuel relay clicking.
and in accessory mode the entire interior power seems to pulse
Old 06-19-2008, 12:08 PM
bad venge's Avatar
bad venge
Section Moderator
start checking the battery cables auxillary fuse block underhood and the wires to the starter
Old 06-19-2008, 06:45 PM
GUANADON's Avatar
GUANADON
GUANADON is offline
All seems fine there. It seems like it might be ignition or computer related.
Old 06-19-2008, 09:12 PM
bad venge's Avatar
bad venge
Section Moderator
I'd bet starter, starter wires, or starter solenoid
Quick Reply: 2000 stratus won't start
