Torque converter lockup switch
Old 05-20-2008, 10:01 PM
rankhornjp's Avatar
rankhornjp
rankhornjp is offline
Default Torque converter lockup switch
http://www.4x4wire.com/dodge/tech/tc_lockup/
Here's a link to a mod thats supposed to allow you to lock your torque converter and keep it locked till you turn the switch off.
Will this work on an '01 1500? Has anyone heard of this/ tried it?
Looking at the pic on the right of the page, could you put a switch inline the jumper wire to turn off the lock-up till you turn back on.
I know leaving it unlocked will increase heat build up, just want to know if it can be done.
James
Old 05-21-2008, 11:16 AM
padodgeram's Avatar
padodgeram
padodgeram is offline
Default RE: Torque converter lockup switch
our rams already have a switch , its the OD off ..
Old 05-21-2008, 12:51 PM
rankhornjp's Avatar
rankhornjp
Even with the O/D off, it still locks up in 3rd (usually right after the shift) which is what i want to stop.
Old 05-22-2008, 08:56 PM
dillonjm's Avatar
dillonjm
dillonjm is offline
Take it into the dealer and have them update your PCM. The updatedprogram disables lockup in 3rd gear.
Old 05-22-2008, 10:44 PM
Shawn86's Avatar
Shawn86
Shawn86 is offline
Now I'm probably going to sound like an idiot, but I'm new at transmissions and trying to understand them. Isn't the lock-up of the torque converter a goodthing since it eliminates the slippage between the engine and transmission? If I'm wrong by all means please correct me but thats how I understand that it works!
Old 05-23-2008, 07:14 AM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
ORIGINAL: dillonjm
really ?
what is the advantage of no lockup in 3rd gear ?
Old 05-23-2008, 11:55 AM
mopowar's Avatar
mopowar
mopowar is offline
ORIGINAL: dhvaughan
ORIGINAL: dillonjm
really ?
When driving at low speeds in 3rd, it takes you out of the torque band when the tc locks.DC calls it a "perceived loss of power". It probably helps to counteract thier earlier flashes that pull all the timing out.
Old 05-23-2008, 11:15 PM
rankhornjp's Avatar
rankhornjp
How much would it cost to have it reflashed??
Quick Reply: Torque converter lockup switch
