2007 RAM 1500 tail light plastic clips
Old 05-19-2008, 09:34 PM
mike749's Avatar
mike749
mike749 is offline
Default 2007 RAM 1500 tail light plastic clips
Anywhere to buy the plastic clips that hold the tail lights on for a 2007 Ram Pickup. Took out the two screws...pulled the light fixture out straight and fast like the manual said. The clips both broke. Dealer wants $16.00 bucks each for what should be a 40 cent plastic clip. Is it going to cost me $32 plus bulbs every time one burns out? HELP Please.
Mike mike749@comcast.net
Old 05-20-2008, 05:14 AM
ivaskaj's Avatar
ivaskaj
ivaskaj is offline
Default RE: 2007 RAM 1500 tail light plastic clips
If it's an '07 and already burned out why were you doing it yourself? Warranty. 1 year old bulbs should still be good.
Old 05-20-2008, 10:33 PM
mike749's Avatar
mike749
mike749 is offline
Thanks for the reply, even though it was of no help to me. I live 37 miles from the dealer. Had the replacement bulb available, so I did it myself. It still isn't right that you can't change a brake bulb without breaking a cheap little plastic clip that they charge a fortune for. Anyway, thanks for the reply.
Old 10-19-2011, 01:44 PM
whitmo1's Avatar
whitmo1
whitmo1 is offline
Default replacement 2007 tail light clips
Here is a site that sells the clips, the dealer said I needed to by new tail lights
http://www.clipsandfasteners.com/Sea...21&Search.y=11
Old 10-19-2011, 10:59 PM
BlueBird8's Avatar
BlueBird8
BlueBird8 is offline
I had this same issue. Instead of forking over money to a dealer, I went to Home Depot and got a couple of rubber grommets in the fasteners section. Something like these:
http://www.grainger.com/Grainger/rub...ecatalog/N-c1x
You can find the right size and they slip securely right in. For a couple of buck it may not be an OEM fix, but it works.
Old 10-19-2011, 11:39 PM
NV290's Avatar
NV290
NV290 is offline
Unless something has changed, light bulbs have never been covered under any vehicle warranty. Same with wiper blades, tires, brake pads, belts, etc.
EDIT: Just went to the Dodge website and checked the warranty and as i thought, Bulbs are NOT covered under warranty.
Quick Reply: 2007 RAM 1500 tail light plastic clips
