1990 dodge d150 ignition problems
Old 05-16-2008, 10:38 AM
mikey821's Avatar
mikey821
mikey821 is offline
Junior Member
Default 1990 dodge d150 ignition problems
Hi folks,
I am new so be patient. my problem is: I just bought this dodge ram d150 and i'm already having problems. the truck will be going down the road fine when it will just shut off.I try to start it and it will not start. I'll try a few times then all of a sudden it will start I took this truck to the mechanic and they said that the distributor was at fault. so after 600.00 bucks I get the truck back and it does the same thing. I check for spark at the plug no spark,I check for spark at the coil no spark. ten minutes later the truck will start and run fine. what can I check next? asd,pcm? where does the power to the coil come from? is it routed through the powertrain control module? or does it come directly from the battery through another relay? Help plz. I like this truck but am not going to sink a fortune in it
Old 05-16-2008, 01:13 PM
driveramsII's Avatar
driveramsII
driveramsII is offline
Default RE: 1990 dodge d150 ignition problems
Check your codes... it should tell ya where to look
Turn key "on"-"off"-"on"-"off"-"on" then count the flashes of the check engine light... "on" is not start
Old 05-16-2008, 08:23 PM
moparborn's Avatar
moparborn
moparborn is offline
First I would go back to the mechanic and complain,for that kind of money you should be having no problems.
Check and clean all related connections,maybe some dielectric grease to.
Old 05-17-2008, 04:54 AM
mikey821's Avatar
mikey821
mikey821 is offline
Junior Member
Thanks guys for the reply.
I went back to the mechanic its in the shop again.originally he
said that there was a problem with the hall effect pickup. but my
thing is if there is no spark to the distributor then the hall effect
pickup would show a code right?.I think instead tracking the problem he went for the first trouble code and replaced the
distributor. these guys are usually good at the electronics.
Old 05-17-2008, 10:01 AM
nemesis_SS's Avatar
nemesis_SS
nemesis_SS is offline
im fairly certain that a bad hall effect sensor should throw a code 11 (no crank/ignition reference signal detected during engine cranking)
by the way some shop manuals give a different explanation for that code.
anyhow just do the old onoffonoffonoffflash check.
and like moparborn says, 600 bucksis real money.
Old 05-17-2008, 10:09 AM
nemesis_SS's Avatar
nemesis_SS
ive googled you problem and somebody on another forum had a cranky engine which started or didnt start at random. he changeda hall effect sensor
Old 05-17-2008, 12:48 PM
mikey821's Avatar
mikey821
mikey821 is offline
Junior Member
Thanks guys I really appreciate the input. I won't get the truck back until mon or so I'll let you know it was driving me crazy.
Old 05-20-2008, 07:49 AM
Jacob1's Avatar
Jacob1
Jacob1 is offline
My truck did this to where it would start only in the afternoon around 3:00, try in the morning and it would just crank. Ended up being the computer was fried. Also since the computer was screwed, it wouldn't show any codes, the conventional way and with a scanner.
Old 05-23-2008, 05:39 AM
mikey821's Avatar
mikey821
mikey821 is offline
Junior Member
well, I got the truck back because they cant reproduce the problem. i went to the store and it stalled. I'm getting ready to send it to the crusherim gonna try replacing the cran position sensor and already replaced the coil I'll let you know
Old 05-23-2008, 09:13 AM
dragonmaster69's Avatar
dragonmaster69
dragonmaster69 is offline
Member
hopefully you got some of your money back or they didnt charge you for this time in the shop. if they did they are bad people because they didnt fix it right th first time.
Quick Reply: 1990 dodge d150 ignition problems
