fan clutch removal
Old 05-15-2008, 10:01 PM
Aruba1's Avatar
Aruba1
Aruba1 is offline
Default fan clutch removal
Is it a right hand thread so I need to unscrew it counter clockwise? I tried by using a long screwdriver between the 2 bolts and a large wrench but that thing does not want to give up. Any ideas?
Old 05-15-2008, 10:30 PM
woligator's Avatar
woligator
woligator is offline
Default RE: fan clutch removal
damn it was pain to remove first time i did it ... left hand tread for this nut buddy
Old 05-15-2008, 10:31 PM
jakebrake's Avatar
jakebrake
jakebrake is offline
top of the blades goes towards the driver's side. If you got a wrench that goes on the hub, leave the belt on. Take a hammer and hit the end of the wrench (redneck impact). Try that a few times. If the belt tension isnt enough to hold it then there is another way if you are replacing the hub. Dont do this if you are not replaceing the hub as it marrs the nut on the hub. Take a cold chisel and a hammer (or an airhammer and a chisel) and strike the edge of the nut (like you are trying to spin it off). After a few times if it doesnt break free, try hitting the wrench again.
Quick Reply: fan clutch removal
